turbo ef question
Old Sep 3, 2007 | 04:33 AM
Wink1100's Avatar
Default turbo ef question
got a d16z6 on turbo I just put together. have a problem with the map code coming on ecu. I'm only running 7-5psi and are running stock injectors. not a big turbo at all. budget. any ideas on how to get rid of the light. seems to happen under load and sometimes comes on starts up. installed a one way check valve in the vacuum lines but, seems not to make a difference. I wanna get rid of this light! idle drops badly and stalls when light is on too. will a motorola map sensor work? i'm using the firewall map assembly. any help would be great. thanks
Old Sep 3, 2007 | 04:51 AM
Sikocivic's Avatar
Default Re: turbo ef question (Wink1100)
You may need to more than one check valve inline. What fuel management are you using?
Old Sep 3, 2007 | 05:06 AM
obd1_crx's Avatar
my buddy had a similar problem. he had to install a GM 3 bar map sensor. i think anything over 3-5 lbs of boost will throw a trouble code and make the car expletive up. also you might wanna look at gettin a hondata s300 and some bigger injectors. you can always take fuel out but its harder to add fuel when you have stock parts.
Old Sep 3, 2007 | 06:39 AM
90dxhmt's Avatar
Default Re: (obd1_crx)
http://cgi.ebay.com/ebaymotors...15818
Wink1100
Sep 3, 2007 06:32 AM
hucoreyCRX
Mar 12, 2007 04:44 PM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
FOrSfEd
May 29, 2002 06:38 PM
