new turbo not running right
Old Mar 8, 2004 | 07:23 AM
turbo89civicb18hatch's Avatar
Default new turbo not running right
i have a 89 civic hatch with an ls turbo. t3-60 turbo 7 psi jackson racing fmu 40 psi at idle stock injectors. i think the problem im having is fuel cut, 1st and second gear are ok but high 2nd and every other gear if u floor it, it makes a loud wooshing sound a/f guage goes to lean and the car has no power. i also get a map sensor code. i think my problem is i need bigger injectors. can someone please help.
Old Mar 8, 2004 | 07:29 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: new turbo not running right (turbo89civicb18hatch)
did you put a missing link or check valves on the map sensor?
Old Mar 11, 2004 | 08:09 AM
i put a longer vacume line from the trottle body to the map sensor. but i will get a check valve that will fix the check engine light but i dont think it will fix the loss of power when i floor it
Old Mar 11, 2004 | 08:17 AM
G
sh!t happens.
Default Re: (turbo89civicb18hatch)
ya put check values in it.. and take it out. then see how it does. i had to pt teo ckeck values in mine.
Old Mar 11, 2004 | 09:26 AM
Mad Cow's Avatar
Make sure you didn't mix up the lines on the FMU. I think the one in the center goes to the firewall, and the other to the regulator... but I you'd better double check. If you put it on backwards, you'll have huge problems like this.
At the very least, you need a checkvalve or missing link. Without that, your car will also have huge problems.
Old Mar 11, 2004 | 09:36 AM
turbodGSR's Avatar
Default Re: new turbo not running right (MadCow)
no missing link or check valves, hmmmmmm
Old Mar 11, 2004 | 10:02 AM
Turbo E's Avatar
no fuel pump either....
doesn't the jackso SC come with a "missing link" type device?
Old Mar 11, 2004 | 10:10 AM
J337_UNIT's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">no fuel pump either....
doesn't the jackso SC come with a "missing link" type device?</TD></TR></TABLE>
dude he doesnt have a jackson racing SC. he has a JR FMU
Old Mar 11, 2004 | 10:14 AM
Turbo E's Avatar
whups.
anyways you still need to trick the MAP sensor.
Old Mar 11, 2004 | 10:59 AM
turbodGSR's Avatar
and i think the JR fmu is like 4:1 also.
wshondaman
Dec 19, 2004 06:36 PM
Blanket Jackson
May 25, 2004 07:59 PM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
Pengo
Jul 30, 2002 08:43 PM
not so civic
Aug 29, 2001 01:19 PM
