Check Valve Help
Old Jul 30, 2002 | 11:53 AM
Pengo's Avatar
Default Check Valve Help
me and my friend finally got his turboed gsr running on boost after we fixed a problem with his wg. now it runs great and that thing is pretty fast. the only problem is that his CEL come on when he's boosting. right now we're running a vortech fmu and 2 check valves right before the map sensor. originally he was running the same 2 check valves but he has them running parallel on both sides of the map sensor. i thought it was kinda useless to have one coming after the map sensor, so i switched them around so the 2 come before the map sensor. i highly doubt that having the 2 is causing the CEL and i'm thinkin maybe we need more. any one have any suggestion to help? beside get a missing link i mean. thanks alot
-alan
Old Jul 30, 2002 | 12:09 PM
filetofit
Guest
Posts: n/a
Default Re: Check Valve Help (Pengo)
Keep adding check valves until it goes away or buy an electronic MAP limiter from me for $20 (or build your own see below).
http://www.angelfire.com/ab7/diymaplimiter/
Old Jul 30, 2002 | 03:16 PM
Wo-Nelly's Avatar
give me $5 for shipping and I'll send you my extra check valves... I think I got 3 or more...
Old Jul 30, 2002 | 08:42 PM
ekb18c's Avatar
Default Re: Check Valve Help (GottaLude)
Try a couple of more check vavles. With 2 check valves the map is reading some boost.
(Vac line from tb)===||===||===||===||=====||===== (Map sensor)
(Those above are check vavles)
That should work, get some tetra check valves. $1.25 at your local pet store.
[Modified by ekb18c, 5:42 AM 7/31/2002]
[Modified by ekb18c, 6:20 AM 7/31/2002]
Old Jul 30, 2002 | 08:43 PM
Pengo's Avatar
Default Re: Check Valve Help (ekb18c)
hey lude, where are u located? my friend mite be interested. what kinda check valves u got?
teggreen4
May 13, 2005 02:12 PM
Johnny_Rocket
Apr 11, 2005 12:35 AM
turbotec
Feb 26, 2002 03:34 PM
