d16 non vtec turbo throws map sensor
Old May 24, 2004 | 11:48 PM
Blanket Jackson's Avatar
Default d16 non vtec turbo throws map sensor
i just put my turbo on the other day. its not some nice kit its just a junk yard kit and i got it all to gether and if i get on it alot the check engine light comes on and it say it the map sensor do i need something so it doesnt turn the check engine light on. sorry if this is and stupid question but i just dont know
Old May 24, 2004 | 11:51 PM
jdm.ej's Avatar
Default Re: d16 non vtec turbo throws map sensor (HONDAofPOKY)
what kind of engine management you got?? are you running check valves??? are you running a mssing link???
Old May 25, 2004 | 12:04 AM
jdm.ej's Avatar
Default Re: d16 non vtec turbo throws map sensor (jdm.ek)
if you just slapp a turbo on a na car without some sort of engine management or using check valves or a missing link. as soon as your map sensor reads boost it will go into limp mode.
Old May 25, 2004 | 05:18 AM
SOHC_MShue's Avatar
please tell me you have some kind of managment
Old May 25, 2004 | 05:21 AM
RobbieG35's Avatar
12 Years Strong
Default Re: d16 non vtec turbo throws map sensor (SOHC_MShue)
Sounds like you need a missing link or check valves. MAP sensor is reading boost throwing the CEL
Old May 25, 2004 | 08:56 AM
Pengo's Avatar
list setup
Old May 25, 2004 | 03:44 PM
where can i get a check valve. and what is a messing link. on i dont have an engine managment
Old May 25, 2004 | 07:59 PM
jdm.ej's Avatar
Default Re: (HONDAofPOKY)
check valves are ****.so i would recomend getting missing link untile you can get hondata or uberdata. but you should realy get either one instead of using a missing link. but you can get a missing link from importparts.com. it goes under you stock map sensor so it want read boost basically
intoracing
Aug 21, 2004 03:02 PM
Blackcivic1
Nov 4, 2002 04:03 AM
NOSED_CRX_VTEC
Oct 18, 2002 06:07 AM
SickRevHrdTeg
Aug 14, 2002 06:11 PM
