Advance Timming with boost and still pre-ignite?
Old Jan 7, 2004 | 11:05 AM
Blaze45's Avatar
Brrraaaap!
Default Advance Timming with boost and still pre-ignite with proper A/F ratio?
Setup t3/t4 550s 91 octane SMC 12lbs of boost outside temp 75deg.
Ok I have a theoretical question. If I were to advance timming, would it lean out my A/F raito and pre ignite? Or would it just preignite and ping while keeping the same a/f ratio? If this doesnt make sense Ill try to explain better, Im just curious to know.... thanks
Blaze
Old Jan 7, 2004 | 11:55 AM
2quik4rwd's Avatar
Default Re: Advance Timming with boost and still pre-ignite with proper A/F ratio? (Blaze45)
should keep same air\fuel rate all you are doing is changing the time the sparkplugs spark when advancing the timing. if you get detination thats bad which could be a few things overheating, timing, fuel octane, leaning out.
Old Jan 7, 2004 | 12:28 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Advance Timming with boost and still pre-ignite with proper A/F ratio? (2quik4rwd)
Anyone else? Thanks for your help.
Blaze
Old Jan 7, 2004 | 12:46 PM
K20EG's Avatar
where are your plugs gapped to ?
93TurboSi
Aug 26, 2004 12:04 PM
willyboyK20
Oct 30, 2002 09:50 PM
dustin
Oct 1, 2002 02:01 PM
hybrid901
Sep 11, 2002 05:33 PM
Sh4rky
Apr 2, 2002 01:34 AM
