Timing under boost
Old Sep 10, 2002 | 07:37 PM
hybrid901's Avatar
Default Timing under boost
I was over a friends house tonight playing with his hondata 4b and wideband. We fix a slight lean condition around 4500-5200 and moved vtec up to 5600 to help a dip around 5200. My timing at 16psi (or whatever hondata uses) was at 2 degrees and we moved it up to 17 degrees. Is 17 to much for 16psi? What are you guys running for timing under full boost.
Old Sep 10, 2002 | 07:50 PM
dustin's Avatar
Default Re: Timing under boost (hybrid901)
Are you on pump gas? What static compression ratio? What turbo?
Old Sep 10, 2002 | 07:56 PM
hybrid901's Avatar
Default Re: Timing under boost (dustin)
9:5:1, t3/4 60-1, 93 octane running 12.1 A/F
Old Sep 10, 2002 | 07:59 PM
dustin's Avatar
I wouldn't run any more than 20 degrees advance. If it still pings, 16-17 might be safe
Old Sep 11, 2002 | 05:56 AM
hybrid901's Avatar
any more input?
Old Sep 11, 2002 | 09:08 AM
lbz34's Avatar
i like to run a little more timing. 22 deg. at full boost is probably the most i would run. I gained 2 mph in the 1/4 adding 2 degrees of timing (24 total) on c16. But i would stay with 18-22.
Sean
Old Sep 11, 2002 | 09:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Timing under boost (lbz34)
Holy crap, I need that boost retard badly. At 10psi, I'm at nearly 44 degrees!
Jeez....luckily I have my EGT to see how long I can boost for. Boosting for 3 seconds at a time sucks. But at least I can drive now that I have a radiator.
Old Sep 11, 2002 | 09:53 AM
VaporTrail's Avatar
New User
Default Re: Timing under boost (shamoo)
your statement makes no sense. 44 degrees is 44 degrees, no matter what your EGT is, thats WAY too much. Remember, EGT's are somewhat slow to react...
Old Sep 11, 2002 | 10:38 AM
shamoo's Avatar
Default Re: Timing under boost (VaporTrail)
I thought your EGT's rise quicker when your timing is too far advanced under boost. My friend who has my setup is running a MSD BTM and can boost for much longer than I can.
I was always led to believe that lower timing yields lower EGT temps...especially since I have a stock ignition and computer.
Old Sep 11, 2002 | 10:46 AM
TurboInteg95's Avatar
I'm at about 25 degrees at 8 psi. Thats about a 7 degree retard from my timing at atmospheric, at 11 psi I'm at about 22 degrees. I wasnt hearing any pinging but I've never really messed with this before so I dont really know what Im' doing. How does that sound?
Old Sep 11, 2002 | 05:33 PM
dustin's Avatar
Read my post in this thread https://honda-tech.com/zerothread?id=274901
93civciv
Dec 4, 2007 05:23 PM
pipes
Feb 20, 2004 09:19 AM
VTC_CiViC
Feb 13, 2004 02:57 PM
TurbodCX
Oct 29, 2002 06:14 AM
808eg6
Jun 24, 2002 07:52 AM
