crank fluctuation sensor bypass
Old Sep 16, 2003 | 06:54 PM
R@mon's Avatar
Default crank fluctuation sensor bypass
I have one quick question,
my freind with a 97 civic ex just ruined his motor running it low on oil. he purchased a jdm d15b (sohc vtec) but the motor doesnt have the sensor, is there any way to bypass the sensor or retrofit it to the new motor? thanks alot in advance
Old Sep 17, 2003 | 01:41 PM
R@mon's Avatar
Default Re: crank fluctuation sensor bypass (93h22a4)
bump
Old Sep 18, 2003 | 07:43 AM
R@mon's Avatar
any one have any ideas? i really need to find out....
Old Sep 18, 2003 | 09:01 AM
IN VTEC's Avatar
Use the ECU that comes with teh JDM motor if possible.
Old Sep 18, 2003 | 01:12 PM
R@mon's Avatar
Default Re: crank fluctuation sensor bypass (IN VTEC)
thats the problem the car is obd2 and the motor is obd1 and he wants to leave everything obd2
Old Sep 18, 2003 | 08:40 PM
IN VTEC's Avatar
It'll be easier to just convert to OBD-1 ECU using a conversion harness and not worry about wiring up the CKF.
The oil pump on there right now might not have the holes to facilitate the mounting of a CKF sensor. And then, there's the wiring and pinning of another set of wires to think about. It's more trouble than it's worth.
Old Sep 21, 2003 | 10:57 PM
deepgreengsr's Avatar
Or you can install a new oil pump on the JDM motor. Place the CA sensor and the toothed wheel from the old motor on the pulley, throw in a new tblet while your at it and run the CAS. Your motor will be better with the CAS and staying obd2 is the way to go. your timeing will be calculated better with the CAS and you will make more power with one installed instead of hacking it until the light goes out.
Old Feb 6, 2007 | 10:23 PM
kaj's Avatar
kaj
Default Re: crank fluctuation sensor bypass (deepgreengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr &raquo;</TD></TR><TR><TD CLASS="quote">Or you can install a new oil pump on the JDM motor. Place the CA sensor and the toothed wheel from the old motor on the pulley, throw in a new tblet while your at it and run the CAS. Your motor will be better with the CAS and staying obd2 is the way to go. your timeing will be calculated better with the CAS and you will make more power with one installed instead of hacking it until the light goes out. </TD></TR></TABLE>
a new tblet?
Old Feb 7, 2007 | 03:02 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: crank fluctuation sensor bypass (kaj)
http://www.ff-squad.com/technet/ckftrick.htm
Old Feb 7, 2007 | 03:47 PM
kaj's Avatar
kaj
Default Re: crank fluctuation sensor bypass (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/technet/ckftrick.htm</TD></TR></TABLE>
great f'ing write up! 'should pass emissions too!
fracas
Sep 15, 2007 07:56 AM
andyvaj
Sep 14, 2007 09:19 AM
yellowmonkeyboy
Sep 26, 2005 11:01 AM
Tuan
Jul 22, 2003 04:29 AM
boostedcrx
Oct 17, 2002 05:03 PM
