VAFC hack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">its just reprogramming the chip</TD></TR></TABLE>
he's right.
he's right.
I always wondered about the hack for all motor.I thought it would work but i didnt know its for by-passing the map.I just figured you lean it out like you would do with a turbo car and just add fuel.How will the car idle with your re-program ecu with 440cc's?
Uh, who can even use 450's for an N/A setup? And without a standalone, I don't think it'll idle very well. But who knows...H-T has a reputation for coming up with theories that go beyond typical ideals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">I always wondered about the hack for all motor.I thought it would work but i didnt know its for by-passing the map.I just figured you lean it out like you would do with a turbo car and just add fuel.How will the car idle with your re-program ecu with 440cc's?</TD></TR></TABLE>
thats not a "hack" thats just using the afc for what it was made for. changing fuel curves
well guys.. said screw it.. and tryed it myself.. i put the dsm 450cc injectors in my 2.3 vtec prelude.. raised the throttle settings on the vafc to 98 and 99 and the wide and narrow settings around -35 to -34 and it runs great.. idles around 750 to 900 and picks up speed great.. thanx to all who gave all info they had.. pe@ce
But is it possibled to run 440's and the vafc like that?What actually is the hack then?
</TD></TR></TABLE>But is it possibled to run 440's and the vafc like that?What actually is the hack then?
teamitr
Mar 10, 2005 09:29 PM
