Apex VAFC controller
Old Mar 20, 2005 | 04:13 PM
Tdawg1030's Avatar
Default Apex VAFC controller
is this good for turbo applications? can i use this instead of getting a new ECU?
Old Mar 20, 2005 | 04:22 PM
Tchleung's Avatar
Default Re: Apex VAFC controller (Tdawg1030)
AFC + Injectors for fueling =
But
AFC + Modifying the map output signal to the ECU and skewwing your IGN valeus right off the scale into detonation zone =
And
Detonation + headgasket =
So
AFC =
There is a few ways around the problem tho.
A: Run as much bosot as your map sensor can take. and then retard your ignition via distributor 2-3 degrees back.
Or
B: Chip the ecu to replot the ignition table values to work properly with say.. -40% correction and go from there(that is if you want to retain the AFC for ease of adjustibility. if not. then while chipping. May as well look into Turboedit/Uberdata etc..
Old Mar 20, 2005 | 04:23 PM
Tdawg1030's Avatar
Default Re: Apex VAFC controller (Tchleung)
so whats that mean
Old Mar 20, 2005 | 04:24 PM
Tchleung's Avatar
It's alot to take in. but jsut reread it a few tiems till it makes sense.
https://honda-tech.com/zerothread?id=841443
Old Mar 20, 2005 | 04:25 PM
Tdawg1030's Avatar
Default Re: (Tchleung)
sry i didnt have time to take it in, i was trying to hurry and decide weather or not to buy it(bid on ebay)
Old Mar 20, 2005 | 04:27 PM
Tchleung's Avatar
what car and what motor and what ecu? I edited my first psot some more. In the end. the AFC WORKS. but it doesn't work very safe unless you do the two options I posted
Old Mar 20, 2005 | 04:29 PM
Tdawg1030's Avatar
so what would be the best route to take?
wantboost's Avatar
Who is Mr Robot?
no matter what motor/car/setup, dont get it... its a half *** way to adjust fueling wether its an na application or an fi app.. my friend is going to run a vafc on his turbo setup, i keep on telling him no, run uberdata. but he wont listen. so im waiting for the day it blows up to tell him "told you so, ***"
Old Mar 20, 2005 | 04:30 PM
Tdawg1030's Avatar
Default Re: (wantboost)
damn, i was soooo close to bidding on tha VAFC, thankfully i ran out of time..... Thanks a lot guys!
Old Mar 20, 2005 | 04:31 PM
Tchleung's Avatar
Default Re: (Tdawg1030)
Anything really. Hondata/Neptune/Microtech/AEM EMS/Uberdata/Turboedit/ZDYNE/There are a **** load of options hehe
Old Mar 20, 2005 | 05:03 PM
Tdawg1030's Avatar
so mircotech would work with a stock ECU??
Old Mar 20, 2005 | 05:29 PM
93turbo16's Avatar
no, microtech is a standalone. Hondata/crome/uberdata and turbo edit work for stock ecus.
CRneXt
Apr 3, 2003 04:01 PM
Slater
Jun 11, 2002 08:02 AM
VTECHGSR
Dec 13, 2001 04:30 PM
schwett
Dec 3, 2001 10:36 PM
