hack for boost? vafc or afc
Old Dec 21, 2004 | 05:46 PM
hatchedzex's Avatar
Default hack for boost? vafc or afc
can u kill two birds with one stone and just use a vafc when runnin low boost and tune accordingly?
Old Dec 21, 2004 | 05:48 PM
aberfoyle's Avatar
Default Re: hack for boost? vafc or afc (hatchedzex)
no
Old Dec 21, 2004 | 05:54 PM
JDMlyfestyle's Avatar
y not go Uberdata or Chrome?
Old Dec 21, 2004 | 06:07 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedzex &raquo;</TD></TR><TR><TD CLASS="quote">can u kill two birds with one stone and just use a vafc when runnin low boost and tune accordingly?</TD></TR></TABLE>
I don't understand how you are "killing two birds with one stone" with it.
A VAFC allows you to alter fuel input at a certain RPM, the problem with the hack is, that it doesn't allow you to adjust ignition tables. The injectors are pulsed slower by hunting for a lower MAP value on the ECU. The problem with this, is that it hunts for a lower ign value as well. This makes the timing a LOT more advanced than it should be, and you need a good bit of base retard to keep from detonating.
You use the base map (-35 across the board) and get a wideband and tune from there until you're happy with your A/F readings.
Old Dec 22, 2004 | 06:54 AM
88crxvtec's Avatar
Default Re: hack for boost? vafc or afc (BauleyCivic)
funny I've been running it for over a year and never detonated, then after throwing it on the dyno at work I see a/f is pretty safe.
Old Dec 22, 2004 | 07:01 AM
FOrSfEd's Avatar
Default Re: hack for boost? vafc or afc (88crxvtec)
There are always good stories about any product but why not go one of the free programs.
Old Dec 22, 2004 | 08:18 AM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxvtec &raquo;</TD></TR><TR><TD CLASS="quote">funny I've been running it for over a year and never detonated, then after throwing it on the dyno at work I see a/f is pretty safe.
where do you work?
Old Dec 22, 2004 | 09:24 AM
88crxvtec's Avatar
Default Re: hack for boost? vafc or afc (RACEPAK)
Total Performance
http://www.4totalperformance.com
also listed on dynojets website
Old Dec 22, 2004 | 10:21 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
A VAFC allows you to alter fuel input at a certain RPM, the problem with the hack is, that it doesn't allow you to adjust ignition tables. The injectors are pulsed slower by hunting for a lower MAP value on the ECU. The problem with this, is that it hunts for a lower ign value as well. This makes the timing a LOT more advanced than it should be, and you need a good bit of base retard to keep from detonating.</TD></TR></TABLE>
WOW.. What genius explained all that to you......
Old Dec 22, 2004 | 11:22 AM
MooreBoost's Avatar
Default Re: hack for boost? vafc or afc (tgreaves)
I wouldnt run either. FMU or Hondata/Uberdata/Turboedit etc.
Old Dec 22, 2004 | 11:36 AM
tgreaves's Avatar
Default Re: hack for boost? vafc or afc (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt run either. FMU or Hondata/Uberdata/Turboedit etc.</TD></TR></TABLE>
I would run an afc hack long before I would do an fmu.. But a tunable ems system is the best option..
Old Dec 22, 2004 | 12:51 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
WOW.. What genius explained all that to you...... </TD></TR></TABLE>
Some crazy republican down the street
Old Dec 22, 2004 | 12:54 PM
tgreaves's Avatar
Some crazy republican down the street </TD></TR></TABLE>
WOW.. He sure is a smart fella..
Old Dec 23, 2004 | 10:30 AM
MooreBoost's Avatar
I would run an afc hack long before I would do an fmu.. But a tunable ems system is the best option..</TD></TR></TABLE>
I ran my 00 JRSC GSR for over 50k miles on an FMU, compression checked out great in the end, and it ran well. I had the hack on my turbo ZC and it ran like **** from day one.
Many, many people do fine with an FMU, hell, most turbo kits come with one. But all it takes is a search to find numerous people who have popped their motors on the hack.
Both perform off the same basic principle, however an FMU won't advance your timing at the worst possible time. Pretty easy decision if you ask me.
Old Dec 23, 2004 | 10:39 AM
tgreaves's Avatar
Both perform off the same basic principle, however an FMU won't advance your timing at the worst possible time. Pretty easy decision if you ask me.</TD></TR></TABLE>
It is a pretty easy decision.. Get a tunable ecu and be done with it..
Old Dec 23, 2004 | 10:48 AM
MooreBoost's Avatar
It is a pretty easy decision.. Get a tunable ecu and be done with it..</TD></TR></TABLE>
Which is why I listed that in my list of options for him.
teamitr
Mar 10, 2005 09:29 PM
hoggy
Sep 22, 2003 06:11 PM
T3T495GSR
Jul 25, 2003 12:48 PM
_Endless_
Jun 20, 2003 10:07 PM
dbman96
Nov 1, 2001 11:22 AM
