Water temp gauge probe, where to install?
Old May 23, 2003 | 04:40 AM
monicle's Avatar
Default Water temp gauge probe, where to install?
Where should I install the water temp probe in a 2k civic?
Old May 23, 2003 | 06:55 AM
turbochic's Avatar
Default Re: Water temp gauge probe, where to install? (monicle)
For my car I spliced into the water temp sending unit on the block near the upper radiator hose. It could be different ona 2k civic, I've also heard you can tap into the thermostat housing.
Also do a search in the archives, thats where I found a lot of my info.
Old May 23, 2003 | 07:03 AM
b18bturbo's Avatar
Default Re: Water temp gauge probe, where to install? (fmaxturbochic)
if you want to do it easy get the greddy temp adapter fits in the radiator hose cut both ends and tap the sensor into the adapter. they have many sizes.
Old May 23, 2003 | 07:39 AM
brcivic411's Avatar
Default Re: Water temp gauge probe, where to install? (b18bturbo)
but doesn't the engine only cycle the coolant through the radiator after the engine has reached optimal temp?
innes887
23
Jun 21, 2007 10:54 AM
S@nt0s
Dec 1, 2003 03:23 PM
Eyewitness
28
Sep 24, 2003 01:06 PM
turbohf
Jan 27, 2003 10:06 AM
HapaHaole
Jan 31, 2002 10:43 AM
