where do i install Autometer water temp sending unit?
Old Jan 30, 2002 | 07:33 PM
HapaHaole's Avatar
Default where do i install Autometer water temp sending unit?
where do most people install the sending unit for an aftermarket water temp gage? is anywhere ok? should it be on the head? near the thermostat? i have no idea. maybe on the water line that runs behind the block???
do i use the stock sending unit even?
[Modified by yeah LS, 8:37 PM 1/30/2002]
Old Jan 31, 2002 | 08:09 AM
internet ay's Avatar
Default Re: where do i install Autometer water temp sending unit? (yeah LS)
i tapped mine into the little elbow that comes off the thermostat b4 the lower radiator hose.
Old Jan 31, 2002 | 10:41 AM
2000_Civic_Si's Avatar
Default Re: where do i install Autometer water temp sending unit? (internet ay)
I am pretty sure you want it before the thermostat becuase everything after will just be the same. I guess.
Old Jan 31, 2002 | 10:43 AM
wreckedagain's Avatar
run a search the is guy that posted pictures and gives good clarity on the bleeder valve, too bad that didnt work for my because its a gsr what a pain in the ***. i still have the sender sitting in a sock in the engine compartment.
PINKS
Mar 12, 2006 12:03 PM
S@nt0s
Dec 1, 2003 03:23 PM
Eyewitness
28
Sep 24, 2003 01:06 PM
monicle
May 23, 2003 07:39 AM
turbohf
Jan 27, 2003 10:06 AM
