Delphi injectors??? anyone every use them
just curious
i have heard that they needed to be modified to fit??
i know u need a resistor box with them but that should be all for them to fit and work with the car.
my 440cc are done at 300whp
i will be going for 400whp soon
with the aem ems...
delphi 62lb r the ones i got
and i could not turn down the deal --- free w00t
with the aem ems...
Running Delphi Precision Turbo 880cc injectors. They need no modification to fit in the rail, just have to double up on the rubber gromets on the bottom side that goes into the intake manifold.
Delphi Precision Turbo 550cc injectors
Used oem upper o-rings and oem rubber manifold gromets. I spaced between the injector body and manifold gromet with an o-ring and used part of a rubber oem upper gromet. Fits fine.
And yes you will need the resistor box
i just bought a set of cpr/550cc saturated injectors from viren. They work well. use factory o ring a top of injector and the one supplied on the bottom works fine. I did have to modify my clips a bit but nothing major. For 200 plus shipping you cant beat this deal for a 550 saturated drop in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">Running Delphi Precision Turbo 880cc injectors. They need no modification to fit in the rail, just have to double up on the rubber gromets on the bottom side that goes into the intake manifold.</TD></TR></TABLE>
exactly what had to be done on mine. The damn things sound like someones pissing.
jetspeedz
Jul 27, 2009 07:14 PM
