RX7 injector question
Old Oct 28, 2002 | 08:19 PM
rbf351's Avatar
Default RX7 injector question
i am able to get a set of RX7 460cc injectors. will they fit on the Si? and do i need to use the resistor box? i've searched all day and haven';t found **** on those
they are coming off an 1991 RX7 and are high imp
Old Oct 29, 2002 | 07:46 AM
1.8T_EG's Avatar
Default Re: RX7 injector question (rbf351)
... if they are bosch style, they should fit... it just might take some modifications... as for the resistor box... if you are sure that they are high impedance, then you should not need a resistor box...
Old Oct 29, 2002 | 08:42 AM
rbf351's Avatar
Default Re: RX7 injector question (1.8T_EG)
they are 460cc high imp injectors from 91 rx7
here is a pic, what does it cost to get them cleaned
Old Oct 29, 2002 | 08:51 AM
Scott - 93HB Si's Avatar
Yes they should fit....I was originally planning to use a set of 850's from the turbo RX7 on my motor.
Old Oct 29, 2002 | 09:40 AM
jas0n's Avatar
Please don't hurt me!
Default Re: RX7 injector question (Scott - 93HB Si)
how much did you pay for them
Old Oct 29, 2002 | 10:15 AM
rbf351's Avatar
Default Re: RX7 injector question (couter)
60 bucks
Old Oct 29, 2002 | 04:27 PM
b18cya's Avatar
no ****!!! sounds like an alternative to teh dsm injectors + resistorbox
Old Oct 30, 2002 | 08:19 AM
1.8T_EG's Avatar
Default Re: RX7 injector question (b18cya)
... yeah, just make sure you know the resistance of the injectors... i have some 550cc rx7 injectors but they are peak-hold... not saturated... so i still need the resistor box...
Old Oct 30, 2002 | 08:39 AM
rbf351's Avatar
how do i check the resistance? and what is it supposed to be?
Old Oct 30, 2002 | 09:18 AM
1.8T_EG's Avatar
... a multimeter should do the trick... peak-hold are low resistance, 2.5-3 ohms... saturated are high resistance, 15-16 ohms...
Old Oct 30, 2002 | 02:27 PM
Phoenix GSR's Avatar
I thought the 550cc FD3 rx7 injectors were saturated?
Old Oct 30, 2002 | 03:59 PM
Dee's Avatar
Dee
Default Re: RX7 injector question (Phoenix GSR)
FC3S Turbo II injectors are saturated 550cc units.
https://honda-tech.com/zerothread?id=154596
Old Oct 31, 2002 | 06:48 AM
1.8T_EG's Avatar
Default Re: RX7 injector question (Dee)
... i dont know what the fc3s is... sorry not an rx7 guy... but from what i have read... i dont know if it is quit that simple... see here : http://www.rx7club.com/forum/showthr...threadid=72980
... also, with my injectors... i had the resistance checked when i had them cleaned and flow tested and again with a multimeter... so i know for sure that i have peak-hold injectors...
(and for those who dont want to follow the link : )
1984-1985 GSL-SE (one pair) 680cc/min top-feed low-impedence
1986-1987.5 non-turbo (two pairs) 460cc/min top-feed low-impedence rectangle plug
1986-1987.5 turbo (two pairs) 550cc/min top-feed low-impedence rectangle plug
1987.5-1988 non-turbo (two pairs) 460cc/min top-feed high-impedence rectangle plug
1987.5-1988 turbo (two pairs) 550cc/min top-feed high-impedence rectangle plug
1989-1991 non-turbo (two pairs) 460cc/min top-feed high-impedence oval plug
1989-1991 turbo (two pairs) 550cc/min top-feed high-impedence oval plug
Old Nov 2, 2002 | 08:45 AM
rbf351's Avatar
i just got them and tested them
they come up with 5 ohms
Old Nov 2, 2002 | 09:29 AM
rbf351's Avatar
i just check my stock ones and they have 5 ohms too, so i guess i can just drop them in without the resistors
please let me know, before i blow something up
Old Nov 2, 2002 | 10:05 PM
1.8T_EG's Avatar
... you should be fine...
Steeve_Civic
Dec 4, 2011 10:11 AM
CivSiClone_96
Dec 20, 2009 05:52 PM
mortificationrock
Jun 10, 2007 09:05 PM
ncervantes
Jan 10, 2005 11:15 AM
Sassafrass
Oct 9, 2004 09:58 PM
