evo 8 injectors
Old Jun 8, 2004 | 11:04 AM
RacerXI's Avatar
Default evo 8 injectors
Has anyone used these in a honda? A friend has a set laying around. thx. A resistor box would be necessary also. TIA
Old Jun 8, 2004 | 02:01 PM
jonnybravo's Avatar
Default Re: evo 8 injectors (RacerXI)
I have the same question about WRX injectors though...They look like they'd work but I'm not sure
Old Jun 9, 2004 | 07:03 AM
99blusi's Avatar
Default Re: evo 8 injectors (jonnybravo)
Measure the resistance and see if the resistor box is needed...probably is though. ALso, fit them into the rail and see if they bolt up. As long as they fit into the rail and the intake manifold, you can make them work.
Old Jun 9, 2004 | 07:50 AM
brkrnu's Avatar
Default Re: evo 8 injectors (99blusi)
My AEM EMS says this:
Mitsu 550cc 2.5 ohm
Scoobies 410cc 12.8 ohm
If that's right the WRX injectors don't need resistors but flow less.
shermanyang
Feb 16, 2011 04:55 AM
WHEELS845
May 26, 2010 11:34 AM
tarheelsoldier
Jan 10, 2007 08:13 PM
slowsi00
Apr 23, 2003 07:11 PM
rbf351
Nov 2, 2002 10:05 PM
