How do you run your coolant line?
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Me neither, had no problems even with custom routing a intake pipe for my turbo.
(IF your talking about a water cooled turbo)
Run a line from the EACV, and just have it recirculate back into where it connected to at the engine block.
Your basically doing this...
EACV-----Turbo-----block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">(IF your talking about a water cooled turbo)
EACV-----Turbo-----block</TD></TR></TABLE>
Yes, but the lines on the IACV are tiny compared to the big heater hose size nipples on the turbo. How do I compensate for the different line sizes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">
Yes, but the lines on the IACV are tiny compared to the big heater hose size nipples on the turbo. How do I compensate for the different line sizes?</TD></TR></TABLE>
You can tee into your heater hoses, the ones that go to the firewall. Run the turbo coolant lines in paralell(tee onto one heater hose for the turbo coolant feed, tee into the other heater hose for the return).
sounds good.
Another question.
The nipple on the side of the turbo facing the block.......Its soo close to the block....
Wont the engine heat melt the heater hose lines? Or heat the lines making the cooling pretty much useless?
Another question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">sounds good.
Another question.
Wont the engine heat melt the heater hose lines? Or heat the lines making the cooling pretty much useless?</TD></TR></TABLE>
I used some Thermo-Tec heat tape on mine, and they were fine, even with one running pretty close to my dp. These were rubber automotive hoses. If you want extra protection, you can get some fire sleeve and cover them with that. I don't think the block itself gets all that hot, but the dp definitely does.
Another question.
