another h22 turbo coolant line thread
Okay, I know I'm beating a dead horse here,
but want to see if I'm on the right wave length...
coolant is sucked from top to bottom of rad, through pipe behind block to water pump,
then through block and back out head.
so,
I plan to run coolant lines from bottom of rad, to turbo, to a tee close to pipe behind block.
In theory, coolant will be sucked through turbo from bottom of rad, to tee near pipe on back of block.
I'm try to "tuck" the turbo water lines, make engine bay less cluttered.
so,
Re: another h22 turbo coolant line thread
I have my IACV coolant lines removed, so I just ran the inlet and outlet to the 2 ports on the t-stat housing. Essentially what pcguy760 did but without the IACV in the loop
