How do you run your coolant line?
Old Apr 21, 2003 | 11:06 AM
soundman's Avatar
Default How do you run your coolant line?
Just wanted to see how everyone out there was running your coolant lines.
Old Apr 21, 2003 | 11:14 AM
PM-Performance's Avatar
Default Re: How do you run your coolant line? (soundman)
? i didnt touch my coolant lines, no need to
Old Apr 21, 2003 | 11:27 AM
DC2R714's Avatar
Default Re: How do you run your coolant line? (itr206)
I think he means for a watercooled turbo, right?
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Me neither, had no problems even with custom routing a intake pipe for my turbo.
Old Apr 21, 2003 | 11:44 AM
*Boostwerks*'s Avatar
(IF your talking about a water cooled turbo)
Run a line from the EACV, and just have it recirculate back into where it connected to at the engine block.
Your basically doing this...
EACV-----Turbo-----block
Old Apr 21, 2003 | 11:45 AM
Default Re: How do you run your coolant line? (Bryson)
water cooled . ohhh.
i dont think i have ever seen one of them , are they a not so popular set up or soemthing ?
Old Apr 21, 2003 | 11:46 AM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">(IF your talking about a water cooled turbo)
EACV-----Turbo-----block</TD></TR></TABLE>
Yes, but the lines on the IACV are tiny compared to the big heater hose size nipples on the turbo. How do I compensate for the different line sizes?
Old Apr 21, 2003 | 12:19 PM
inspyral's Avatar
Default Re: How do you run your coolant line? (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, but the lines on the IACV are tiny compared to the big heater hose size nipples on the turbo. How do I compensate for the different line sizes?</TD></TR></TABLE>
You can tee into your heater hoses, the ones that go to the firewall. Run the turbo coolant lines in paralell(tee onto one heater hose for the turbo coolant feed, tee into the other heater hose for the return).
Old Apr 21, 2003 | 12:27 PM
intekragsr's Avatar
Default Re: How do you run your coolant line? (inspyral)
sounds good.
Another question.
The nipple on the side of the turbo facing the block.......Its soo close to the block....
Wont the engine heat melt the heater hose lines? Or heat the lines making the cooling pretty much useless?
Old Apr 22, 2003 | 07:07 AM
soundman's Avatar
On my 90 CRX, does the Intake manifold have coolant lines running to it? If so I could just use those right?
Old Apr 22, 2003 | 08:27 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">sounds good.
Another question.
Wont the engine heat melt the heater hose lines? Or heat the lines making the cooling pretty much useless?</TD></TR></TABLE>
I used some Thermo-Tec heat tape on mine, and they were fine, even with one running pretty close to my dp. These were rubber automotive hoses. If you want extra protection, you can get some fire sleeve and cover them with that. I don't think the block itself gets all that hot, but the dp definitely does.
megomaniac
May 19, 2011 05:57 AM
purple98ek
Aug 13, 2007 10:50 PM
Rubixcu7
Jul 11, 2005 08:27 PM
hatchracer02
Jan 24, 2005 08:14 AM
T25 civic
Sep 24, 2002 02:33 PM
