autometer oil pressure guage
Old Jan 10, 2003 | 12:02 AM
ShortbusEK's Avatar
Default autometer oil pressure guage
from the looks fo it i have to run an oil line to the guage... correct me if im wrong.. so where would i hook up the oil line? on the engine i know but is there a spot on the d16's where i could hook it to?
Old Jan 10, 2003 | 01:37 AM
iH8RICERZ's Avatar
Default Re: autometer oil pressure guage (95DelSolSI)
i'm curious as well on to where to hook up the oil line, but i got a GSR......any difference compared to the d16?
Old Jan 10, 2003 | 03:47 AM
CrotchRocket's Avatar
Default Re: autometer oil pressure guage (iH8RICERZ)
GSR application: I've taken out the oil pressure sender (in the back of the block, couple of inches below the throttle body, i think its a 22mm) and replaced it with the autometer fitting (mechanical gauge). It worked great for me. You can also get a T fitting to have both the gauge and the sender connected. Correct me if I'm wrong guys.
Old Jan 10, 2003 | 04:50 AM
tbkonwso's Avatar
Default Re: autometer oil pressure guage (CrotchRocket)
yea you take out the oil sending unit than use the t brass fitting to send oil through the gauge. the oil feending you need a 24mm socket i beleive. kinda hard to reach but you'll get it. wish i had a picture to show you. make sure you use a stainless braided sending unit thou. i have the hks one and its copper or something n ot sure..and braided which is good thing, duno how the autometer one is. btw this is for the d16y8
[Modified by tbkonwso, 1:50 PM 1/10/2003]
Old Jan 10, 2003 | 08:35 AM
Cynical 1's Avatar
http://www.theoldone.com/articles/oilpressure/
I have mine done this way, and it works great.
Just make sure to coat all the fitting's threads with a drop of Hondabond to prevent leaks.
And NO, you do not run the line directly to the guage. You have to T into the factory sender hole, and have both the Autometer and factory sending unit installed, or you will get a CEL for oil pressure and VTEC will not work.
[Modified by Revolveu2, 11:37 AM 1/10/2003]
Old Jan 10, 2003 | 08:49 AM
sparq's Avatar
Default Re: autometer oil pressure guage (Revolveu2)
Ive got an electric guage if you dont want to deal with plumbing in an oil line to your guage
Old Jan 14, 2003 | 11:35 AM
CTR94Joes's Avatar
Default Re: autometer oil pressure guage (sparq)
I went the same route. It's easier to go with the Ele one.
Old Jan 14, 2003 | 11:55 AM
ImportechPerformance's Avatar
Default Re: autometer oil pressure guage (CTR94Joes)
Yep the electric one is better and safer than the mech one but not as accurate
Old Jan 14, 2003 | 11:56 AM
can i ask you guys that have gotten an electric one were you have purchased it from and for how much?
Old Jan 14, 2003 | 12:29 PM
CTR94Joes's Avatar
Default Re: autometer oil pressure guage (TheRedSkoolingBus)
Try ebay.com that's where I got mines from. But you can buy it from any auto store, being that your from PR, I would try to get a SuperStreet mag or any import mag and just order it from there.
B2uce
Apr 25, 2007 09:47 AM
Vtak
Apr 29, 2005 11:24 AM
BlueShadow
Apr 11, 2005 01:17 PM
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
