autometer oil pressure guage
from the looks fo it i have to run an oil line to the guage... correct me if im wrong.. so where would i hook up the oil line? on the engine i know but is there a spot on the d16's where i could hook it to?
Re: autometer oil pressure guage (iH8RICERZ)
GSR application: I've taken out the oil pressure sender (in the back of the block, couple of inches below the throttle body, i think its a 22mm) and replaced it with the autometer fitting (mechanical gauge). It worked great for me. You can also get a T fitting to have both the gauge and the sender connected. Correct me if I'm wrong guys.
Re: autometer oil pressure guage (CrotchRocket)
yea you take out the oil sending unit than use the t brass fitting to send oil through the gauge. the oil feending you need a 24mm socket i beleive. kinda hard to reach but you'll get it. wish i had a picture to show you. make sure you use a stainless braided sending unit thou. i have the hks one and its copper or something n ot sure..and braided which is good thing, duno how the autometer one is. btw this is for the d16y8
[Modified by tbkonwso, 1:50 PM 1/10/2003]
Re: autometer oil pressure guage (95DelSolSI)
http://www.theoldone.com/articles/oilpressure/
I have mine done this way, and it works great.
Just make sure to coat all the fitting's threads with a drop of Hondabond to prevent leaks.
And NO, you do not run the line directly to the guage. You have to T into the factory sender hole, and have both the Autometer and factory sending unit installed, or you will get a CEL for oil pressure and VTEC will not work.
[Modified by Revolveu2, 11:37 AM 1/10/2003]
Re: autometer oil pressure guage (sparq)
Ive got an electric guage if you dont want to deal with plumbing in an oil line to your guage
Re: autometer oil pressure guage (CTR94Joes)
Yep the electric one is better and safer than the mech one but not as accurate
can i ask you guys that have gotten an electric one were you have purchased it from and for how much?
Re: autometer oil pressure guage (TheRedSkoolingBus)
Try ebay.com that's where I got mines from. But you can buy it from any auto store, being that your from PR, I would try to get a SuperStreet mag or any import mag and just order it from there.
Vtak
04-29-2005 11:24 AM
W O T
01-29-2005 08:01 PM
Nextelbuddy
07-13-2003 07:44 PM
