automatic to 5-speed conversion
Old Dec 11, 2002 | 03:06 PM
RICE POLICE SIP's Avatar
Default automatic to 5-speed conversion
I'm getting ready to convert my wifes automatic eg four door to a 5speed..... I was just wondering if anyone knows of a website or knows how to do this themself.... i'm just trying to gather as much info as i can.... thanks
Old Dec 11, 2002 | 03:24 PM
civic dx's Avatar
Default Re: automatic to 5-speed conversion (92boostn'hatch)
me too
Old Dec 11, 2002 | 03:56 PM
RoAnSa's Avatar
Default Re: automatic to 5-speed conversion (civic dx)
yeah, does anybody have some information how to do this???
[Modified by RAS612, 1:57 AM 12/12/2002]
Old Dec 11, 2002 | 04:03 PM
Jin Yamato's Avatar
Default Re: automatic to 5-speed conversion (RAS612)
http://autotrader >> sell
http://autotrader >> buy
OK..sorry..couldn't resist..
I know it's possible but quite expensive.
Old Dec 11, 2002 | 04:06 PM
chad's Avatar
Moderator
hmmm...do a search....
Old Dec 11, 2002 | 04:12 PM
scdarksol's Avatar
Hi, I was going to do this to my brother's 93 hatch, but he got a 95 coupe in stick instead, but I did do research on how to do it before. First of all you need to get a 5-speed transmission, clutch master cylinder, the pedals, shift linkage, shifter, shift ****, and you'll also need the line that goes from the clutch master to the tranny, and you'll need to buy a special engine mount from HA sport. If you need any of these I have a tranny, shift linkage, shifter, pedals. Make me an offer if your interested.
Old Dec 11, 2002 | 05:20 PM
Turbo Powa's Avatar
Default Re: automatic to 5-speed conversion (scdarksol)
i'd like to know too.
Old Dec 11, 2002 | 06:01 PM
Nifty's Avatar
Default Re: automatic to 5-speed conversion (Panda EK)
http://tech.hybridgarage.com/tech/5g...to-manual.html
Old Dec 11, 2002 | 07:27 PM
youngkow's Avatar
Default Re: automatic to 5-speed conversion (Nifty)
https://honda-tech.com/zerothread?id=273253 Check this out. Here is all of the parts you need. Its pretty easy if your doing an engine swap. If your doing a tranny swap only, seems like a big pain in the a$$.
Old Dec 11, 2002 | 08:25 PM
hoya_10fintec's Avatar
there's couple things more... why spend money and time on modifying mounts???
---for the driver side engine mount: get any 92-95 civic MT mount or integra mounts(with the bracket)... 'cause ur old one won't fit...
---for the upper tranny mount: get one from PlaceRacing... or if u wanna save some $$ then go take a look at the bracket that's holding UPPER tranny mount right below ur intake pipe... do u see it?
notice how it sits on an angle? manual civic tranny bracket sits straight(side to side)... you need to get that bracket from Honda and replace it(welding and cutting required)... and then get a manual tranny upper mount...
sorry... if that didn't explain enough.. my English isn't that good...
i hope this helps...
[Modified by hoya_10fintec, 5:26 AM 12/12/2002]
[Modified by hoya_10fintec, 5:36 AM 12/12/2002]
Old Dec 11, 2002 | 08:27 PM
TurboTeG4's Avatar
Default Re: automatic to 5-speed conversion (hoya_10fintec)
I did that conversion and its very easy!!!! 3 and half hours done, made my own side bracket out of steel , its better then stock
Old Dec 11, 2002 | 10:59 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i have done five of these, including my own conversion. i have done cable and hydro conversions...civics, accord, and eclipse. if anyone needs help with their civic then e-mail b18bhybrid@hotmail.com or aim sn is kevlarkian.
Old Dec 11, 2002 | 11:02 PM
JDMvtecDRAGSTA's Avatar
listen to this guy he knows what hes talking about.
i did same thing.
Old Dec 11, 2002 | 11:08 PM
Default Re: automatic to 5-speed conversion (not so civic)
I don't have to modify anything if the motor is coming from an eg and going into an eg would I.... When i buy the swap it's coming with EVERYTHING..... tranny, shiftlinkage, axles, mounts and everything etc..... So i shouldn't have to modify anything right?!?!?!?!?
Old Dec 12, 2002 | 03:34 PM
civic dx's Avatar
to much work i will sell mine or stay automatic
Old Dec 12, 2002 | 03:44 PM
vivid02's Avatar
It is not a lot of work. Just go to the junk yard and get all the parts needed. The only hard part would be tranny mount brakcet on the automatic eg frame rail. You either take off the old one btw it is welded on there or call place racing and they should have a mount.
Old Feb 25, 2003 | 04:19 PM
VRD^don's Avatar
i have so mounts. look below...
Old Feb 25, 2003 | 05:29 PM
civic dx's Avatar
Default Re: automatic to 5-speed conversion (sohc_vtec)
if you are talking about the trany mont on the frame, they are like $30+ from honda
Old Feb 25, 2003 | 05:51 PM
VX's Avatar
VX
To all of you AUTO TO MANUAL guys: these are just some of the threads i found while searching, there are alot more:
https://honda-tech.com/zerothread?id=416110
https://honda-tech.com/zerothread?id=264493
https://honda-tech.com/zerothread?id=376506
https://honda-tech.com/zerothread?id=359385
https://honda-tech.com/zerothread?id=292000
https://honda-tech.com/zerothread?id=161087
Old Feb 25, 2003 | 06:54 PM
MyWhiteCivic's Avatar
Default Re: automatic to 5-speed conversion (VX)
Manual, I don't need no stinking manual. I think I will be staying with my automatic at 10 psi. And I am still going to keep it at 1.2 bar.
Old Feb 25, 2003 | 07:02 PM
The G2 Racer's Avatar
It's not that expensive to do when you do a swap. Just some parts.
grandtheftlunchbox
May 12, 2008 05:17 PM
JDMhighrev
May 1, 2005 06:24 PM
4door93civic
Oct 29, 2003 09:58 AM
midorigreen.
Oct 19, 2003 02:49 PM
hatchback19
Mar 18, 2003 08:52 PM
