turbo gsr problems
so my old build is starting to burn oil quite a bit under boost. Rebuilt the turbo and still pushing smoke. pulled the screamer pipe off the wastegate to see if that was pushing smoke and it isn't.
now im confused because the spark plugs look fine. not soaked in oil.
It has a catch can with 2 valve cover lines going into it. the catch can is empty.
anyone have this issue?
you have to be specific WHEN the smoke is occurring. (During acceleration, deceleration, idle, etc). That could be anything from the piston rings in the block to the valve seals in the cylinder head.
can you give more information as to exactly when the oil smoke is occurring?
