Oil pump broken (x2)
Old Aug 24, 2011 | 02:14 AM
b18T01's Avatar
Default Oil pump broken (x2)
Hi guys ı have serious problem ,
breaking the oil pump 2 times from same place ,where do you think the real problem, thanks to for your answers.
setup:
b18a2 w/vtec(b16 head), itr cams, 9+cr
gt30 turbo 8000rpm 1 bar
itr oil pump 2 times broken
added photo for broken parts
Old Aug 24, 2011 | 02:50 AM
cpl rampage's Avatar
Default Re: Oil pump broken (x2)
ouch, what crank pulley are you using?
Old Aug 24, 2011 | 03:08 AM
b18T01's Avatar
lightweight crank pulley
(only crank pulley)
Old Aug 24, 2011 | 03:42 AM
mar778c's Avatar
Community Builder
Community Influencer
That pulley is the problem.
Old Aug 24, 2011 | 04:19 AM
Muckman's Avatar
Moderator in Chief
People still use those?!
Old Aug 24, 2011 | 04:29 AM
NY GsR's Avatar
get rid of that pulley ASAP. that is the problem
Old Aug 24, 2011 | 05:15 AM
Hulkdon1's Avatar
The Unorthodox pulley is a good concept on paper, not with boost. That is your problem. The rotation of the bottom end is out of harmony. For a NA motor, that pulley may work well, but with all the pressure of boost, all of the motor's tolerances will be checked. Be sure to change the oil filter, oil and clean the oil pan. Some of the little particles from the gear may be still there.
Stock pulley or liquid filled aftermarket. GL.
Old Aug 24, 2011 | 05:21 AM
b18T01's Avatar
thanks for answer I will check that , but this pulley working fine almost 3 years.
where else is problem
Old Aug 24, 2011 | 06:33 AM
th3pwn3r's Avatar
Your mains are off then. Keep breaking pumps until you figure it out I guess. Good luck.
Old Aug 24, 2011 | 07:26 AM
scarvalho's Avatar
i have the same problem on my bosst b16
aftermarket crank polleys NEVER
Old Aug 24, 2011 | 10:14 AM
civickiller's Avatar
+1 if u change pulley and same thing happens
Old Aug 24, 2011 | 10:32 AM
DDTECH's Avatar
ignorance.. Marc already told you what the problem is.. run a standard GSR or LS crank pulley and you'll never break another pump again..
Old Aug 24, 2011 | 10:41 AM
met's Avatar
met
I like the ati damper because you can rebuild it down the road. The fluid damper and ati both claim there are better and the other sucks but I have seen and read about many setups with both doing very well. This link i am posting is a good writeup of why you need a good damper.
http://www.atiracing.com/products/da...mper_dinan.htm
Even if there is a problem with your mains the damper will just compound the issue.
Just my 2 cents, the link is worth the read if nothing else.
Old Aug 24, 2011 | 12:40 PM
W!d3b0dYr3X's Avatar
Get a new pump install it and use feeler gauges to go around the crank where it goes through and check the clearance. There should be little drag and equal amounts all the way around if not you will have to grind the dowels a little to move the pump in the direction it needs to go.
Old Aug 24, 2011 | 12:55 PM
boostedteg909's Avatar
another thing u can check while that pump is off jus to b sure is the clearance on the rotors while installed. if the main bearing caps were align-bored at any point in time, that may b puttin excess pressure on the rotor inside the pump. do as W!d3b0dYr3X said
Old Aug 24, 2011 | 02:54 PM
b18cya94's Avatar
have u had the rotating assembly balanced? if not that combined with those pulleys thats where your problem is. get balanced and a fluiddampr, or ati..
Old Aug 24, 2011 | 04:01 PM
Gunmetal_B20_Hatch's Avatar
If your mains have been line-bored a considerable amount, this can happen also...
Old Aug 24, 2011 | 06:13 PM
vwbased's Avatar
have a nice day
Old Aug 24, 2011 | 06:20 PM
viper_boy403's Avatar
...this pulley working fine almost 3 years.
obviously not
Old Aug 24, 2011 | 06:30 PM
jdm inc's Avatar
get rid of it and buy an ati damper
Old Aug 24, 2011 | 08:05 PM
Turbo B18C EJ6's Avatar
buy stock pulley=problem solved., unless you have had a align bore done on your mains or main studs installed.
Old Aug 25, 2011 | 01:22 AM
b18T01's Avatar
thanks for answers ,we will use a ati street damper high probability
Old Aug 25, 2011 | 08:12 AM
Turbo-LS's Avatar
ATI street damper FTW or OEM is cheap if not free. bt the ati will absorb alot more harmonics than oem. First post sa the broken pump and immediatly thought N1 type r pulley LOL but yeah those lightweight aftermarkets are crap
Old Aug 25, 2011 | 10:50 AM
NA James's Avatar
Ati street. I broke a oil pump because of a old fluidamper.
Old Aug 25, 2011 | 12:11 PM
Charlie Moua's Avatar
yeah my buddies turbo b16 just cranked his oil pump too... he was running the ctr pulley...
