just boosted now smoke
Old May 30, 2005 | 06:06 PM
SoSlo's Avatar
Default just boosted now smoke
i just put on my turbo and i am getting what looks like blue smoke. it would only smoke a little during full throttle before boost but now any throttle over 40% will give me a crap load of smoke. i plan on doing a comp test tonight but what else could it be?
Old May 30, 2005 | 06:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: just boosted now smoke (SoSlo)
seals on the turbo are shot...
Old May 30, 2005 | 06:14 PM
SOHCmaster's Avatar
is the hose from valve cover hooked into the IC pipe or do you have a breather on there, check PVC valve too.
Old May 30, 2005 | 06:31 PM
SoSlo's Avatar
Default Re: (PK SPEED)
my comp on a jdm gsr is
222 222 205 205 i dont have a leekdown tester
the turbo is brandnew
teh valve cover breather is filtered.
how do i check the pvc?? are my comp # causing it??
Old May 30, 2005 | 06:36 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (SoSlo)
doesnt matter if the turbo is brand new... seals can go bad in 5 minutes of idling... what does your oil return look like... how big is it? any kinks? where does it drain into the pan?
Old May 30, 2005 | 06:38 PM
SOHCmaster's Avatar
Default Re: (SoSlo)
Take pvc out and shake it, if it rattles its good, if not get new one
Old May 30, 2005 | 06:40 PM
SoSlo's Avatar
Default Re: (wantboost)
i am using a stealthmode kit with his oil restricter teh oil return is not kinked and it is above the oil llevel
Old May 30, 2005 | 08:22 PM
SoSlo's Avatar
Default Re: (SoSlo)
please help i need to drive in the morning
Old May 30, 2005 | 08:58 PM
DohcVtecCrx's Avatar
Default Re: (SoSlo)
I agree with what he said about the seals in the turbo...mine does the same...mine is over 6 grand.....even at idle...because my oil pressure goes over a certain rpm at 6 grand....if you need to drive it then ****....drive it.
Old May 31, 2005 | 03:10 AM
Finland's Avatar
pull and read the plugs, if they look fine, then the turbo is the culprit (assuming your PCV system is proper)
Old May 31, 2005 | 07:18 AM
turbo_civic_si's Avatar
your oil return line might not be high enough. i had a similar problem where i was blowing smoke. i had the turbo rebuilt and still did the same thing. i bought another turbo and still did the same thing. i tapped the block for the oil return and haven't had a problem since. one way to know would be oil dripping out the compresor outlet. crankcase pressure is forcing oil back up the return and over flowing out the seals. the other is to check your plugs and see how they look like. you can also remove the turbo and see if your engine is smoking. might not always be the turbo. another thing would be valve stem seals. those are easily over-looked.
Old May 31, 2005 | 04:18 PM
SoSlo's Avatar
Default Re: just boosted now smoke (turbo_civic_si)
teh retun is about 3/4 of an inch from teh top of the oilpan. the plugs dont show oil they are just really rich
ay_billy
Jul 13, 2012 07:06 PM
sleepercivic88
Apr 10, 2009 05:57 AM
superslow-oto
Jun 11, 2008 10:57 AM
BmCRace.com
Mar 29, 2004 07:13 AM
1337 Si
Oct 7, 2003 05:27 AM
