turbo gsr problems
Old Aug 29, 2017 | 12:19 AM
wolfcalibur's Avatar
Icon4 turbo gsr problems
so my old build is starting to burn oil quite a bit under boost. Rebuilt the turbo and still pushing smoke. pulled the screamer pipe off the wastegate to see if that was pushing smoke and it isn't.
now im confused because the spark plugs look fine. not soaked in oil.
It has a catch can with 2 valve cover lines going into it. the catch can is empty.
anyone have this issue?
Old Aug 29, 2017 | 05:09 AM
TheShodan's Avatar
Moderator
Default Re: turbo gsr problems
the catch can only has to do with crankcase pressure, which is nothing to do with the symptoms that you're looking at. The turbocharger being rebuilt Also may not have had to have been rebuilt, so at least that has been taken care of already, even then though it may not have been necessary.
you have to be specific WHEN the smoke is occurring. (During acceleration, deceleration, idle, etc). That could be anything from the piston rings in the block to the valve seals in the cylinder head.
can you give more information as to exactly when the oil smoke is occurring?
sleepercivic88
Apr 10, 2009 05:57 AM
crxt25turbo
Apr 16, 2008 08:25 AM
CRXdan
Nov 23, 2007 06:52 PM
SoSlo
May 31, 2005 04:18 PM
civictypenos
Jun 19, 2004 07:27 PM
