Any ideas on routing this oil drain- downpipe clearance issue
Old Jan 16, 2017 | 04:40 PM
2kdrift's Avatar
Default Any ideas on routing this oil drain- downpipe clearance issue
so anyone have ideas on how to route this drain, I have 2 an ports on my oil pan (one cannot be seen in ohoto it is directly behind downpipe) both dont quite clear from what I can see, my only idea is to weld another bung on to the far drivers side of the pan. other then that I think ill just cut dumptube a bit shorter
thanks
Old Jan 17, 2017 | 08:22 AM
93h2beg's Avatar
Default Re: Any ideas on routing this oil drain- downpipe clearance issue
Dang, seems like it always something.
Does anyone do hard line? Since the turbo and oil pan shouldn't move independently of one another, could a compression type fitting slip around your down pipe?
Only reason I bring it up, on my barracuda I have a dual line external oil pickup with rubber hose and once the oil is hot the lines flex a lot. I would be concerned with it rubbing on the down pipe and melting😲
Old Jan 17, 2017 | 09:37 AM
TheShodan's Avatar
Moderator
I would honestly use a braided steel line with a thermal sleeve over the lie to route to the drain. I would also thermal wrap both that part of the downpipe and dumptube for better insulation, in which none of the other substances would melt.
I would go against the idea of a hardline at that point, mainly because of the amount of flex that the engine will see there. Even oil return lines from the OEM turbo cars are at least spring loaded to allow that flex and vibration.
Old Jan 17, 2017 | 10:19 AM
2kdrift's Avatar
Already ordered a new pan I will weld in a bung on the far drivers side (similar to what moroso has) and loop it arround. I considered a fire sleeve but I think heat wrapped pipes should do the trick
Old Jan 17, 2017 | 10:24 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
one can always loop a few coils into a hardline to prevent work-hardening from the vibrations. Would it be feasible in a turbo drain line? I'm thinking this line would be too big.
Old Jan 17, 2017 | 10:40 AM
TheShodan's Avatar
Moderator
For these sized turbochargers, yes. But its quite normal for OEM turbocharged applications.
Old Jan 17, 2017 | 11:06 AM
LightningTeg's Avatar
Community Builder
Do the fire sleeve. Works better and less messy.
Old Jan 17, 2017 | 03:01 PM
2kdrift's Avatar
thanks, looks like im gettin the sleeve anyway but pipes will still be wrapped to cut down on heat for a multitude of reasons, A/C / radiator / underhood temps etc
Old Jan 18, 2017 | 02:48 AM
Community Builder
Yeah its always a good idea.
Old Jan 19, 2017 | 06:04 AM
B and B's Avatar
Loved
Community Favorite
That downpipe is beautiful
Old Jan 19, 2017 | 03:25 PM
2kdrift's Avatar
haha thanks, yea I like it. Just a pain to redo this drain,
in my head I was sure I would never need to retap my pan since it already had 2 ports on it. Going for a new pan I dont want a bunch of ports on it just increases chances of one of them leaking
Old Jan 20, 2017 | 05:53 AM
want2na's Avatar
show us some pictures of the finish drain line when u finish. Am in the same situation to. thanks
Old Jan 20, 2017 | 02:51 PM
2kdrift's Avatar
I can do that.
Its going to the far right with a 45* off the turbo, the line is a lil bit over a foot long from my mockup
Old Jan 22, 2017 | 02:18 AM
tony_2018's Avatar
Fish Twig
braided oil line with fire sleeve.
Old Jan 22, 2017 | 12:06 PM
2kdrift's Avatar
yes stainless steel line with fire sleeve
Old Jan 27, 2017 | 10:37 AM
Roy Leyva's Avatar
Easy and faster, just make another hole to the pan
Old Jan 28, 2017 | 06:15 PM
2kdrift's Avatar
went with a new pan so i could do this without having the 2 other nipples, one of which was pretty close to the DP
EG6 Love
Sep 6, 2015 02:30 PM
MalcolmV8
Dec 5, 2011 05:29 PM
ashb82
Mar 22, 2010 12:50 PM
SM00TH976
May 17, 2006 08:59 AM
MCP486
Jan 19, 2003 09:33 AM
