Any ideas on routing this oil drain- downpipe clearance issue
Old 01-16-2017, 04:40 PM
2kdrift's Avatar
Default Any ideas on routing this oil drain- downpipe clearance issue
so anyone have ideas on how to route this drain, I have 2 an ports on my oil pan (one cannot be seen in ohoto it is directly behind downpipe) both dont quite clear from what I can see, my only idea is to weld another bung on to the far drivers side of the pan. other then that I think ill just cut dumptube a bit shorter
thanks
Old 01-17-2017, 08:22 AM
93h2beg's Avatar
Default Re: Any ideas on routing this oil drain- downpipe clearance issue
Dang, seems like it always something.
Does anyone do hard line? Since the turbo and oil pan shouldn't move independently of one another, could a compression type fitting slip around your down pipe?
Only reason I bring it up, on my barracuda I have a dual line external oil pickup with rubber hose and once the oil is hot the lines flex a lot. I would be concerned with it rubbing on the down pipe and melting😲
Old 01-17-2017, 09:37 AM
Moderator
TheShodan's Avatar
I would honestly use a braided steel line with a thermal sleeve over the lie to route to the drain. I would also thermal wrap both that part of the downpipe and dumptube for better insulation, in which none of the other substances would melt.
I would go against the idea of a hardline at that point, mainly because of the amount of flex that the engine will see there. Even oil return lines from the OEM turbo cars are at least spring loaded to allow that flex and vibration.
Old 01-17-2017, 10:19 AM
2kdrift's Avatar
Already ordered a new pan I will weld in a bung on the far drivers side (similar to what moroso has) and loop it arround. I considered a fire sleeve but I think heat wrapped pipes should do the trick
Old 01-17-2017, 10:24 AM
-Intl Steve Krew
Caoboy's Avatar
one can always loop a few coils into a hardline to prevent work-hardening from the vibrations. Would it be feasible in a turbo drain line? I'm thinking this line would be too big.
Old 01-17-2017, 10:40 AM
Moderator
TheShodan's Avatar
For these sized turbochargers, yes. But its quite normal for OEM turbocharged applications.
Old 01-17-2017, 11:06 AM
LightningTeg's Avatar
Do the fire sleeve. Works better and less messy.
Old 01-17-2017, 03:01 PM
2kdrift's Avatar
thanks, looks like im gettin the sleeve anyway but pipes will still be wrapped to cut down on heat for a multitude of reasons, A/C / radiator / underhood temps etc
Old 01-18-2017, 02:48 AM
Yeah its always a good idea.
Old 01-19-2017, 06:04 AM
B and B's Avatar
That downpipe is beautiful
Old 01-19-2017, 03:25 PM
2kdrift's Avatar
haha thanks, yea I like it. Just a pain to redo this drain,
in my head I was sure I would never need to retap my pan since it already had 2 ports on it. Going for a new pan I dont want a bunch of ports on it just increases chances of one of them leaking
Old 01-20-2017, 05:53 AM
want2na's Avatar
show us some pictures of the finish drain line when u finish. Am in the same situation to. thanks
Old 01-20-2017, 02:51 PM
2kdrift's Avatar
I can do that.
Its going to the far right with a 45* off the turbo, the line is a lil bit over a foot long from my mockup
Old 01-22-2017, 02:18 AM
Fish Twig
tony_2018's Avatar
braided oil line with fire sleeve.
Old 01-22-2017, 12:06 PM
2kdrift's Avatar
yes stainless steel line with fire sleeve
Old 01-27-2017, 10:37 AM
Roy Leyva's Avatar
Easy and faster, just make another hole to the pan
Old 01-28-2017, 06:15 PM
2kdrift's Avatar
went with a new pan so i could do this without having the 2 other nipples, one of which was pretty close to the DP
EG6 Love
09-06-2015 02:30 PM
MalcolmV8
12-05-2011 05:29 PM
ashb82
03-22-2010 12:50 PM
SM00TH976
05-17-2006 08:59 AM
MCP486
01-19-2003 09:33 AM
Quick Reply: Any ideas on routing this oil drain- downpipe clearance issue
