where to tap for oil drain line?
i've heard that you are supposed to tap above the oil line in the pan so that there's no restriction, but even if you do it directly into the oil itself, shouldn't it still be able to drain freely? either way the oil should fall down into the pan, whether o not it flows directly into the oil it shouldn't matter right?
i'd appreciate first hand experience replies only. i know what "should" be better in regards to common notions, but has anyone tapped it below the oil level and had good luck?
Re: (RudeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">yep</TD></TR></TABLE>
Do you know what you're meaning by that? You actually have you're oil line tapped into the downpipe? If so: Tell your motor for me and I give it my best.
EDIT:
1.) Perhaps tapping your oil line into the downpipe caused this problem: https://honda-tech.com/zerothread?id=1142582
2.) Alas! I caught you fibbing https://honda-tech.com/zerothread?id=1332526!
EDIT:
Re: (SM00TH976)
To answer your original question though: put the bung as high as you can on the oil pan. Just plan ahead so that you don't put the bung right under a bolt that holds the oil pan on (for obvious reasons). Also put the bung in a location that allows the return line to be as straight and as downward as possible.
Re: where to tap for oil drain line? (SM00TH976)
http://members.shaw.ca/estangleis/crx/IMG_1169.jpg
theres mine.. bout as low as u wanna go. i know its ghetto fab but its held up for 8 months.
Re: (AF-P Dunc)
gad dammit....that problem was caused by my stupid actions. i had the timing belt running to the alternator. i'm telling you, the best to put ur oil return is into ur downpipe.
Re: (RudeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">gad dammit....that problem was caused by my stupid actions. i had the timing belt running to the alternator. i'm telling you, the best to put ur oil return is into ur downpipe. </TD></TR></TABLE>
Re: (AF-P Dunc)
^^^ lol no he didn't. I just read this thread and its still funny
its clear he has no idea what he is saying. I'd love to see what an oil return routed into your DP looks like haha
honda-tech
honda-tech
Re: (DJ Gurgla GSR)
guys i was kidding, but i do agree that the joke is kinda dead now. i dont have my oil return goin to my dp. and i dont recomend anyone that reads this thread to do it. i dont think it would run quite right like that.
D16y8_619
09-08-2006 09:05 PM
