96 Civic DX - Speedometer help
Old Apr 23, 2016 | 07:42 AM
Erocer's Avatar
Default 96 Civic DX - Speedometer help
Need some help with a speedometer.
I can be a. And my speedometer says I'm doing a hundred and twenty miles an hour and then it bounces down to 40 and spins around like a how to control clock.
I have a 96 Civic DX I replaced the module on the transmission didn't do any good.
Anybody got any ideas what's going on?
Old Apr 23, 2016 | 07:50 AM
jonsey1886's Avatar
10 Year Member
Default re: 96 Civic DX - Speedometer help
Is fuse 15 (driver's side kick panel) blown?
Fuse 15 TSB for 96-00 Civics
Old Apr 23, 2016 | 07:53 AM
Erocer's Avatar
Give me 15 to 30 minutes just waking up getting coffee and me. And will check
Old Apr 23, 2016 | 08:45 AM
Erocer's Avatar
Default Re: Speedometer help
I'm getting a 14.5 volts on both sides of a fuse
Old Apr 23, 2016 | 09:23 AM
Former User's Avatar
Default Re: 96 Civic DX - Speedometer help
^Dash fuse 15 (7.5A)? Does the cluster battery light turn on and stay on when key is turned to ON(II) [engine off]
Is CEL code 17 or any other CEL codes thrown?
https://honda-tech.com/honda-civic-d...lists-1901557/
Old Apr 23, 2016 | 09:37 AM
Erocer's Avatar
The fuse is good #15 under dash. I've never even had a code out of this one time which is kind of surprising no engine light flashing nothing and I don't know how many times I've plugged in a OBD2/EOBD code reader and it's never come up with anything ever been like this a very long time
Old Apr 23, 2016 | 09:55 AM
Does your code reader also read live data? If so, does it report proper mph while the speedometer is acting up?
Old Apr 23, 2016 | 10:03 AM
Erocer's Avatar
It does report live but I've never really thought to do that. Give me a few minutes to move some vehicles around plug-in the reader and and run down the road and see what happens give me a little time
Old Apr 23, 2016 | 10:22 AM
Erocer's Avatar
The OBD2 did show miles per hours
Old Apr 23, 2016 | 10:24 AM
Scout junk yards for a replacement speedometer or an Civic EX cluster with a tachometer.
Old Apr 23, 2016 | 10:25 AM
Erocer's Avatar
Do you mean the part that shows your engine heat Fuel and speedometer and all the lights and stuff for the engine seat belts junk like that.
Old Apr 23, 2016 | 10:30 AM
If you can find an EX cluster matching your transmission, it's plug and play for your Civic, which currently does not have a tachometer. Or you can swap in a LX, DX, CX speedometer that matches your transmission.
Old Apr 23, 2016 | 10:38 AM
Erocer's Avatar
Well I may be in luck my brother-in-law had an accident in his 96 Civic it was a stick mine is automatic he bought another one for parts stripped it down gave a wiring harness with a another speed sensor in instrument cluster like one that you're describing just doesn't have a tachometer it's pretty much stock like I have on my car. Have not tested it to see if it's any good or put it in yet.
But a instrument cluster with a tachometer would be pretty darn cool.
And I still have to make a jumper switch for my air conditioner and I did find another board on eBay for 17 or $16
Old Apr 23, 2016 | 10:41 AM
Old Apr 23, 2016 | 10:44 AM
Erocer's Avatar
Again thank you for your help I owe you that's two times you save my butt. I'm pretty sure you know it's starting already get hot outside. But I'm going to look into the one with a tachometer to that is pretty cool if it's not too pricey that is.
Again thank you
Old Apr 23, 2016 | 10:57 AM
Erocer's Avatar
Originally Posted by RonJ
Old Apr 23, 2016 | 11:13 AM
I've been on vacation in San Francisco and Los Angeles.
I return to Houston late tonight.
Old Apr 23, 2016 | 03:37 PM
Erocer's Avatar
Didn't get a chance even read that last post you're on vacation you're more like on Worcation. Gheez so glad you are manning the computers.
Well I pull the speedometer out the other one and I saw all that yellow plastic must have been white at one time but because of the Heat and age it's turned yellow. It's also the kind of plastic when it gets real old shattered like glass
Is there anything I can maybe put on there or paint on their to give it more little longevity. I was thinking maybe an epoxy paint but Epoxy paint has got acetone in it and acetone attacks plastic.
Any ideas I value your opinion
richard203
10
Jul 23, 2015 09:50 PM
demo024
17
May 10, 2011 08:18 PM
shivic
Jan 19, 2011 04:16 PM
Luiz_aka29
12
Aug 15, 2009 08:56 PM
Jason-
Feb 6, 2006 08:14 PM
