sway bar options for my 97 four door
how's it going guys?
I'm looking to put a sway bar on the rear of my 97 four door. what are my options?
I've heard the gsr sway bar will bolt right up.. true? I have blox rear lower control arms.
how about a bigger one for the front? what brand? I'd like the thickest one that's reasonable.
links/any info / pictures you've got would be dope. let me know, thanks.
_isiah
_isiah
Re: sway bar options for my 97 four door
Here's a freebie; https://www.google.com/search?site=&....3.UrdTWclBdbU
eH.
Ill post my setup.
running rear ITR sway bar ( 22mm I believe ) , with 99-00 SI links and oem control arms. and ASR rear brace.
Works fantastic . ( dont have super stiff springs, so makes a nice difference, im sure if I were to run a much stiffer spring it would be different)
Also running a 24mm OEM acura 1.6 EL ( from canada ) front sway bar. Similar to CTR end links.
GSR will also work , as long as you use the SI 99-00 rear end links ) . the GSR not being super thick shouldnt rip off the mounting points, but if the car has seen salt, I would get a rear brace.
92DAIntegraXSI
07-10-2007 04:06 AM
