mechanical or electric boost guage
I wanted to know what kind of boost gauge you guys running and if it electric or mechanical and why? Am debating on what to get and which one is easier to install
he said electronic, not digital. You can have an electronic gauge with an analog display. I've always used electronic (peak recall, overboost warning, no vacuum lines to run inside, etc) but analog gauges do tend to react faster.
i love my AEM tru boost (digital) matches my AEM wideband perfectly. Install took me about 45 to an hr installing both gauges. I can change boost levels in the car pretty quickly.
On electronic guages do you need a map sensor i saw you need one on a post?
Who is Mr Robot?
Iirc tru boost is a gauge and boost controller in one. Totally useless if your ems supports boost control. Personally I won't run aem products unles there's no other choice. They don't really "make" anything, just license existing products from other companies and put their name on with their packaging. Only reason I'm using an aem standalone on my accord is I got it for free.
Typically mechanical gauges are cheaper and have less components that could fail. However most mechanical gauges aren't 100% accurate. Elevation, temperature, humidity, and age can all skew the readings.
Electronic gauges are hyper accurate, at least the name brand ones that use stepper motors are, an unlike the mechanical gauges this doesn't change over time unless you have an issue. That being said they are more expensive, and have more parts to damage: sensor, sensor harness, etc. while like said above it is best to view datalogs for info, having a gauge with a peak recall function can be useful for adjusting boost levels as well as diagnosing simple problems faster than having to hookup a laptop, datalog, and review. Things like boost creep, spikes, under boost conditions, surge/choke, and fluctuations can all be seen by simply hitting a button and comparing the max to what your setting is supposed to be.
i just run a mechanical autometer, gets the job done. its really just for reference, the s300 datalogs are used for fine tuning.
i couldnt justify a $125 price difference for electric boost gauge. my oil and water are electric though
After 12 years, my old school GReddy mechanical gauges (Same manufacturer as Defi) still is on point with my management to .01BAR
Autometer Sport Comp series did well too. But like with everything else, you only get out of it, what you put into it.
I have the sport comp II now and its about 2-3psi off, my old ultra lite was closer.
Figures my ebay glowshift from 2008 was the most accurate of the 3 and the cheapest =P
Flamenco-T
Aug 7, 2001 07:49 PM
