Inaccurate Boost Gauge???
Old Feb 23, 2007 | 05:51 AM
driveahonda's Avatar
Default Inaccurate Boost Gauge???
Can a boost gauge go bad?
As soon as I floor my gas pedal my boost guage needle jumps past the 20psi mark and keeps going. Can a boost gauge somehow read double what it should?
I am confused.
Old Feb 23, 2007 | 06:05 AM
swappedcx's Avatar
Default Re: Inaccurate Boost Gauge??? (driveahonda)
yes it can, mine read 6-7psi making 11-14...it was horribly wrong (autometer sport comp)
Old Feb 23, 2007 | 06:10 AM
xsi-t's Avatar
It's possible but I would try to get a reading from the MAP first
Old Feb 23, 2007 | 06:11 AM
SOHC_MShue's Avatar
Default Re: Inaccurate Boost Gauge??? (swappedcx)
from my experience autometer is the suck
Old Feb 23, 2007 | 06:13 AM
Thanks guys.
I also have an autometer. What would be a better / more accurate brand to go with?
Old Feb 23, 2007 | 07:04 AM
building boost's Avatar
lol may it's not reading wrong. i dont know what tuning device you're using but you should see what the map is reading.
Old Feb 23, 2007 | 08:44 AM
carnot's Avatar
Default Re: (driveahonda)
id also like to know what other brands people are using and if they seem accurate or not. When i first got my autometer it read fine but it seemed as the weather got colder it would read like 6psi of vacuum when the motor was off. The differential between the actual boost and gauge reading is constant whether in vacuum or boost. I know this because I am tuned for 10psi with an 11.5psi boost-cut and at peak boost the gauge only reads around 4psi. Is there anyway to set the needle back at 0 when the motor is off?
Old Feb 23, 2007 | 09:46 AM
zexxbo's Avatar
Default Re: (carnot)
defi, greddy and hks make good gauges. theyre a little more on the pricey side, but with good reason.
Old Feb 23, 2007 | 09:51 AM
xsi-t's Avatar
I have never had a problem with Autometer gauges in customer's cars. The only gauge I run in my personal car is an AEM UEGO wideband. I'm not saying problems dont exist with Autometer gauges though
Old Feb 23, 2007 | 09:56 AM
Alfa Turbo's Avatar
VDO makes quality gauges and you don't have to rent out your sister to pay for them like Defi's...
Old Feb 23, 2007 | 10:00 AM
zexxbo's Avatar
Default Re: Inaccurate Boost Gauge??? (Alfa Turbo)
whats wrong with renting out your sister?
Old Feb 23, 2007 | 10:04 AM
BoostedEG6's Avatar
Default Re: Inaccurate Boost Gauge??? (zeimbo)
as soon as I read the title of this thread I said to myself.... its got to be an autometer gauge
Old Feb 23, 2007 | 10:56 AM
blinx9900's Avatar
Default Re: Inaccurate Boost Gauge??? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">as soon as I read the title of this thread I said to myself.... its got to be an autometer gauge </TD></TR></TABLE>
x2
greddy ftw!
Old Feb 23, 2007 | 12:54 PM
Whats the going rate for the sister?
And I will look into the VDO, I have a hookup with Siemens/VDO anyways.
Old Feb 23, 2007 | 12:59 PM
A.E Motoring's Avatar
no problems here with autometer, i would look at some datalogging, take a look at the map on there, ever think maybe your boost spiking?
skuded
Apr 21, 2011 04:38 PM
FRernesto
Aug 29, 2007 07:01 AM
hondaaccord94
Aug 9, 2006 05:19 PM
JDM_EH2
Sep 18, 2003 09:10 AM
