d16y8 Best crankshaft swap???
Old Mar 11, 2015 | 05:43 PM
Blackcougar141's Avatar
Default d16y8 Best crankshaft swap???
So, I was wondering if the d16z6 crankshaft is a better option than the d16a6 crankshaft? My 97 came with the y8 crank but I need to swap it out for another one because mine is shot. I will be running a turbo soon with the obd2 to obd1 conversion so I'm not worried about a knock sensor. What is everyone's thoughts on this? Anyone have a crank for sale??? Lol...I'm in Kentucky...
Old Mar 11, 2015 | 05:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: d16y8 Best crankshaft swap???
The Z6/A6 cranks both have dual oil journals. For a Y8, the Z6 crank is the only way to look if you want to upgrade from the original.
Old Mar 11, 2015 | 05:57 PM
I thought the a6 crank had 2 holes as well....I guess I was misinformed. Guess I'll be looking for a z6 crank for sale...
Old Mar 11, 2015 | 06:01 PM
NotARaCist's Avatar
Like I said, the A6 crank DOES have dual oil journals.
Old Mar 11, 2015 | 06:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you read his whole post, he says it does have dual oil ports... However being he says the Z6 is your only option for the Y8, it would indicate the A6 won't fit the Y8 mains.
Old Mar 11, 2015 | 07:00 PM
NotARaCist's Avatar
I honestly don't know if it'll fit. I also don't know if there are any timing differences, and if there are, what those differences are. We're talking about putting an OBD0 crank in an OBD2 engine. Z6 into Y8 has been done hundreds of times, and is tried and true. No reason to reinvent the wheel.
Old Mar 11, 2015 | 07:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Makes sense too me. I like tried and true way better than testing and failing unless you got the money for it.
Old Mar 12, 2015 | 03:35 AM
Thanks for the advice guys! I'll be going with the z6 crank then. I bookmarked a few different threads on modifying the block too. You guys are a big help! Thanks again!!!
Old Mar 12, 2015 | 10:11 AM
24TEN's Avatar
PHANTOM MENACE
Timing differences occur in how the camshaft is clocked. TDC is the same for all cranks, when #1 is completely at it's peak height. Just throwing that out there.
Old Mar 13, 2015 | 06:48 AM
jad67's Avatar
I don't know personally but I believe I read on the dso site that it is a direct swap. So much so that I purchased a Z6 crank for my D series build. I have sold the car since then and still have the crank shaft which is for sale if you are intrested.
I live in tn and will be in ky tomorrow...
Alfa Q the 2nd
Mar 9, 2012 12:17 PM
SpoonfedCivic
Feb 23, 2011 07:30 AM
TheCivicMafia
May 23, 2010 08:31 PM
b20accord
Aug 18, 2007 06:44 PM
O16581724 5 2 5
May 20, 2005 09:50 AM
