z6 crank in y8??
z6 crank in y8??
I have a good y8 block but a fucked crank but i have a z6 crank. Are they the same thing?? They look exactly the same?? Only the oil holes look different?? Is there any problems if i run a z6 crank in a y8?? thanks!
Re: z6 crank in y8?? (ek forever guy)
Yes, they interchange. Basically, the only difference between the a6/z6 crank and y7/y8 crank is the a6/z6 has chamfered oiling holes and the y7/y8 does not. a6 and z6 are same part number, too...
Ek Forever y0!
Re: z6 crank in y8?? (RyanA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanA »</TD></TR><TR><TD CLASS="quote">Yes, they interchange. Basically, the only difference between the a6/z6 crank and y7/y8 crank is the a6/z6 has chamfered oiling holes and the y7/y8 does not. a6 and z6 are same part number, too...</TD></TR></TABLE>
So would a d16y8 benefit from the chamfered oiling holes? I would think so..
a6, a6z6y7y8, block, compatible, cons, crank, crankshaft, difference, differences, fit, holes, oiling, y7, y8, z6
