Grinding noise when clutch is released
Old Nov 1, 2014 | 08:20 AM
Papalou's Avatar
Default Grinding noise when clutch is released
I drive a 98 Honda Civic. It makes a grinding noise when the clutch is released in any gear and 3rd is the loudest. It even makes the noise it neutral when the clutch is released. The engine and tranny have 150k on it and the body has 223k. What would make that noise? and how hard of a job would it be?
Old Nov 1, 2014 | 08:23 AM
Former User's Avatar
Default Re: Grinding noise when clutch is released
By released do you mean pedal is up or pressed down?
Old Nov 1, 2014 | 08:28 AM
Papalou's Avatar
the pedal is up. yeah i guess thats confusing lol
Old Nov 1, 2014 | 08:29 AM
Bad transmission main bearing is the general cause.
Old Nov 1, 2014 | 08:33 AM
Papalou's Avatar
damn that would probably cost like a grand if i take it to the shop huh?
Old Nov 1, 2014 | 08:37 AM
If you are unable to remove your transmission, crack it open, and replace main bearings, then your best option may be to shop for a used/rebuilt replacement transmission.
Old Nov 1, 2014 | 08:57 AM
Papalou's Avatar
ok thanks man
Old Nov 1, 2014 | 08:59 AM
Good luck with the fix.
Old Nov 1, 2014 | 04:56 PM
Jaxis's Avatar
you probably got some time before the bearing goes completely out. I've read some people driving 2 years with a bad throw out bearing. mine is making noise too.
Old Nov 1, 2014 | 05:18 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
It's not the throw out bearing. That makes noise with the clutch pedal depressed. The input shaft bearing makes noise with the clutch pedal released.
eH.
Old Nov 2, 2014 | 05:24 AM
crvtectim's Avatar
Basically, the trans needs a bearing and seal kit rebuild or swapped out, as stated already.
Old Jan 4, 2021 | 08:42 PM
aryeff ishak's Avatar
For my case when i press clutch noise gone. after i release clutch paddle noise come out (like in neutral).
Here is my video regarding this problem and solution for my case.
Tyler Harteau
Jan 4, 2021 08:45 PM
hurlygurl33
Honda Civic (2001 - 2005)
May 21, 2016 05:40 AM
fatsheep
13
Jul 8, 2010 01:02 PM
GRANT!
Oct 20, 2009 11:14 AM
sracing
Aug 27, 2003 09:50 AM
