Grinding noise when clutch is released
Old 11-01-2014, 08:20 AM
Papalou's Avatar
Default Grinding noise when clutch is released
I drive a 98 Honda Civic. It makes a grinding noise when the clutch is released in any gear and 3rd is the loudest. It even makes the noise it neutral when the clutch is released. The engine and tranny have 150k on it and the body has 223k. What would make that noise? and how hard of a job would it be?
Papalou is offline
Old 11-01-2014, 08:23 AM
Former User's Avatar
Default Re: Grinding noise when clutch is released
By released do you mean pedal is up or pressed down?
Former User is offline
Old 11-01-2014, 08:28 AM
Papalou's Avatar
the pedal is up. yeah i guess thats confusing lol
Papalou is offline
Old 11-01-2014, 08:29 AM
Bad transmission main bearing is the general cause.
Old 11-01-2014, 08:33 AM
Papalou's Avatar
damn that would probably cost like a grand if i take it to the shop huh?
Papalou is offline
Old 11-01-2014, 08:37 AM
If you are unable to remove your transmission, crack it open, and replace main bearings, then your best option may be to shop for a used/rebuilt replacement transmission.
Old 11-01-2014, 08:57 AM
Papalou's Avatar
ok thanks man
Papalou is offline
Old 11-01-2014, 08:59 AM
Good luck with the fix.
Old 11-01-2014, 04:56 PM
Jaxis's Avatar
you probably got some time before the bearing goes completely out. I've read some people driving 2 years with a bad throw out bearing. mine is making noise too.
Jaxis is offline
Old 11-01-2014, 05:18 PM
yippee-ki-yay
eHMxhACk's Avatar
It's not the throw out bearing. That makes noise with the clutch pedal depressed. The input shaft bearing makes noise with the clutch pedal released.
eH.
eHMxhACk is offline
Old 11-02-2014, 05:24 AM
crvtectim's Avatar
Basically, the trans needs a bearing and seal kit rebuild or swapped out, as stated already.
crvtectim is offline
Old 01-04-2021, 08:42 PM
aryeff ishak's Avatar
For my case when i press clutch noise gone. after i release clutch paddle noise come out (like in neutral).
Here is my video regarding this problem and solution for my case.
aryeff ishak is offline
Tyler Harteau
01-04-2021 08:45 PM
hurlygurl33
Honda Civic (2001 - 2005)
05-21-2016 05:40 AM
fatsheep
13
07-08-2010 01:02 PM
GRANT!
10-20-2009 11:14 AM
sracing
08-27-2003 09:50 AM
Quick Reply: Grinding noise when clutch is released
