fuel system for my 14b dsm mitsu homemade turbo
Old Oct 29, 2002 | 07:36 PM
Superorb's Avatar
Default fuel system for my 14b dsm mitsu homemade turbo
hey, im new here, i wanna see what u guys think...
im getting a 14b turbo and a 1g dsm manifold since the ports line up to my f22 motor in my accord, all u need to do is redrill the holes.. anyways, im on a tight budget, and i am getting the turbo and manni for a STEAL, so how can i further save money on a fuel system. ive got the 1g bov already, and i can get a set of the 450cc injectors, should i get these also, or use the stock accord injectors. i will be boosting no more than 6psi, most likely 4psi for the 1st few months or maybe less to make sure its all working right. fmu, or vafc, or hondata, or what... i dunno.
Old Oct 29, 2002 | 08:03 PM
rjardy's Avatar
Default Re: fuel system for my 14b dsm mitsu homemade turbo (Superorb)
well if you want to save money and your going to be running that low of boost, then i say stick with your stock injectors and get an FMU with a 12:1 calibration disk.
Rob
Old Oct 29, 2002 | 08:12 PM
CzanSOHC's Avatar
Default Re: fuel system for my 14b dsm mitsu homemade turbo (rjardy)
or get some 450cc's and use the SMC.
Old Oct 29, 2002 | 08:22 PM
WA  DA  TA's Avatar
does the manifold really line up that well?
Old Oct 29, 2002 | 09:32 PM
asianspeed's Avatar
Default Re: fuel system for my 14b dsm mitsu homemade turbo (gsx4R1)
talk to filetofit about him making a diymaplimter for you....which works like the afc hack. But he fabricates his own circuit for about $20. I'm going to running his map limiter as soon as I get 450cc injectors.
Old Oct 29, 2002 | 10:11 PM
fire7882's Avatar
Default Re: fuel system for my 14b dsm mitsu homemade turbo (CzanSOHC)
Old Oct 30, 2002 | 08:38 AM
Superorb's Avatar
Default Re: fuel system for my 14b dsm mitsu homemade turbo (fire7882)
whats an SMC???
what exactly does this do and how would it be good for me for the setup i am going to be running?
ken
Old Oct 30, 2002 | 08:57 AM
pelotudo's Avatar
https://honda-tech.com/zerothread?id=310021
Go w/ the SMC. ~100 + injectors and you're set...
jB
Old Oct 30, 2002 | 09:28 AM
PureCRXtasy's Avatar
New User
If you're on a budget, like me, I'd say definately go with Filetofits custom circuit. I have it myself with a set of 450 mitsu injectors.. the whole thing cost me $55 for WAY better than FMU fuel mgmt for much less money. You can build your own A/F gauge for about $10 and get a cheap VDO Boost gauge and you're all set. Easy, Cheap and Effective.. all the Fuel mgmt you need for less than $100..
slotec
May 26, 2005 05:39 PM
BuddyLee
May 20, 2003 07:56 PM
1.8Tities
Mar 15, 2003 09:00 AM
DsMWookie
Sep 16, 2002 11:23 AM
simonsez
May 14, 2002 12:55 AM
