DIY Vtec controller?
Old Oct 20, 2002 | 07:42 PM
Turbo Powa's Avatar
Default DIY Vtec controller?
Anyone have any ideas on building your own vtec controllers? Is it possible? Let me know! Thanks!
Old Oct 20, 2002 | 07:53 PM
Turbo Powa's Avatar
Default Re: DIY Vtec controller? (Civic LX 29)
Anyone??????
Old Oct 20, 2002 | 09:01 PM
tonyxcom's Avatar
Not really a good idea.
Old Oct 20, 2002 | 09:06 PM
Kamin's Avatar
Default Re: DIY Vtec controller? (tonyxcom)
Old Oct 21, 2002 | 11:47 AM
Turbo Powa's Avatar
Default Re: DIY Vtec controller? (KAMiN)
LMAO Kamin. Aiite mods delete this post please.
Old Oct 22, 2002 | 02:22 AM
ion_four's Avatar
So, are you one of 'those people' that don't do anything yourself, or atleast anything new? Boo for trying to keep the man down. He didn't ask if you thought he should do it.
Anyway, it is kind of complicated because V-TECHK engagement is determined by coolant temp/oil pressure/vehicle speed/rpm and maybe more? SO, you'd have to modify all those inputs...or, maybe just get an MSD rpm activated switch, replace the "pill" with a 5k ohm potentiometer, so you can adjust it to whatever you want (0-~6500rpm) (then wire up a relay so this makes a ground, rather than a 12v signal) and then put that in place of the solenoid signal (ground) wire from the ECM and you might be able to lower vTeKCH a little without throwing a code...If you raised it in this manner, I think you might throw a code without changing other signals, since all the signals would show a 'go' to the ECM, but nothing would happen as far as VTECH is concerned.
Old Oct 22, 2002 | 08:17 AM
B18Redline's Avatar
not a good idea. Just get one, leave the vtec controllers to the pros
Old Oct 22, 2002 | 08:55 AM
carolinaACCORD's Avatar
Default Re: DIY Vtec controller? (Redline07)
i agree that its not really a good idea, also, but if you really wanna know, check out the tech articles on http://www.accordinglydone.com
Old Oct 22, 2002 | 03:26 PM
Turbo Powa's Avatar
Default Re: DIY Vtec controller? (carolinaACCORD)
Thanks guys!
cleanazcoupe
Jun 29, 2009 08:37 PM
green91
Dec 29, 2004 06:43 PM
DsBananas94LS
Dec 5, 2004 07:51 PM
davken1102
Aug 2, 2003 06:01 PM
Accord15
Jan 11, 2002 03:28 AM
