Boosted dohc zc help/ideas
run down
xenocron basemap
450cc dsm blue tops
ebay turbo set up
vitara pistons
eagle rods
dohc zc now 6:1
obd0 chipped pm6
stock fuel pump
stock fpr
fuel filter pressure gauge when car is not on but primed says about 38psi
has half tank of gas, i know cause i just put in 5 gallons
Car wont start up at all with the 450s in there and new basemap
before it was on the old basemap with 240cc injectors. ran ran shity after about 30 seconds or so.
I thought maybe one of the 450s was bad so i tested to see if they sprayed and they do.
Odd thing is after cranking the car for a bit and not starting up i took the injectors out to see if they were spraying and with the injectors out the car fired up and burned what fuel that was in the cylinders
so what ya think could be up with this??
xenocron basemap
450cc dsm blue tops
ebay turbo set up
vitara pistons
eagle rods
dohc zc now 6:1
obd0 chipped pm6
stock fuel pump
stock fpr
I think you might be on to something about the weak spark. Its not a bright spark really.
I assume it needs to be a really good spark due to the 450s and the 6:1.
Guess time to get new dizzy.
The dizzy in there now did throw code 8 but it went away after a little cleaning.
Thanks for fast reply
If it started with the 240 then my guess is that is dumping too much fuel. You also mention when you took off the 450 it started with whatever fuel left which is very little this leads me to believe that it is dumping to much fuel. Try playing with your dizzy advance/retard and start it up if it will help.
idk what to think now iv tried both ways. lining up direct gave me code 8
DOHC ZC won't idle. Dizzy problem? - TheZCR.com Forums
What does this mean "Wont take gas dies"? if you apply gas pedal does it stay running?
I love to see the engine bay, any pic? ADjust the trottle cable while its been running, have a friend keep foot on the pedal keep it running til warm up or keep idle at 2000rpm.
IF your car starts with the stocki'sh ecu and 240cc it ain't compresssion. Open up your valve lash a bit or play with ignition on dizzy while its running.
take a propane torch and open the valve and stick it up to the opening in your intake manifold , more or less adding more fuel to the engine , if your car stays running you know its a fuel problem and not a timing , or electrical
did this to my 79 mustang to wake her up from a 15 year nap in the garage
ok riddle me this only 2 plugs are working lol
hard to see but look in the center of screen and just down and to the left
dumb civic - YouTube
[IMG]
Uploaded with ImageShack.us[/IMG]
Uploaded with ImageShack.us[/IMG]well did a compression test i really hope the valves need adjusting lol/
110 9ish 90ish 110 lol yes the throttle was wide open and this is dry
and rechecked timing and looked at the holes in cams and stuff they line up great the exhaust cam hole is maybe off a 16th off from showing straight threw if that makes since pic
i have read 2 things about timing both from people that have done alot with these motors.
one says time it like i have it, the other says line up the lines, **** idk lol
Tips:
In the future, you are more likely to get help, if that is what you were hoping for, by succinctly posting a specific tech question rather than a large collections of quotes.
A thread title that summarizes your tech question not only has positive benefits but also is required. See forum Rules sticky at the top.
I gave all the quotes to show what has been done so far. First quote was my question why it wouldnt start.
Sorry for any confusion. Just thought it be easier done this way to answer any new question that might have came up.
It was just difficult to decipher what you actually needed.
Skimmed through the laundry list and didn't see what I was looking for.
I do see you have done a compression test.
Have you checked for spark?
Checked to make sure fuel is making it out of the injectors?
Verified mechanical timing (your exhaust cam bothers me)?
ninty1civic
Nov 29, 2010 07:32 AM
