I can't get my turbine housing to budge for the life of me...
Hey guys, I'm trying to install my custom kit today (woohoo) but I need to clock my turbine housing about 1/4 of the way around. I was able to do the compressor side easy but this turbine side is so rigid it feels like it is welded to the center cartridge itself. I have loosened all the bolts and the little brackets are just hanging there. Anyone know if it is supposed to be this hard to turn? I dont have a vice either
Re: I can't get my turbine housing to budge for the life of me... (javierb14)
i beat the crap out of it...we're talking the "die you *****#&@#$* piece of $hit" screaming and coming down with all of your might too. It's not budging, i even already took chunks out of my rubber mallet too. damnit i'm so pissed...i knew this kind of crap was going to happen today
[Modified by KC GSR, 4:14 PM 9/6/2002]
Re: I can't get my turbine housing to budge for the life of me... (KC GSR)
Get some liquid wrench. Saturate the edge between the center housing and the turbine housing. Let it sit for a while.
Repeat.
Now, somehow fit the turbo in a vice, and with the rubber mallet beat the heck out of the turbine housing until it breaks loose. It eventually will. The crap rusts together
Repeat.
Re: I can't get my turbine housing to budge for the life of me... (CovertFI)
i used a 5lbs sleg
edit: I just got off the phone with Majestic and he said I gotta use a blow torch...damnit this is aggravating me. I wake my *** up at the crack of dawn to install my kit and I haven't even opened the hood yet
[Modified by KC GSR, 4:43 PM 9/6/2002]
Re: I can't get my turbine housing to budge for the life of me... (BoOsTeD_eK)
anyway you could turn on th ecar and let it idle so the exhaust gas heats up the turbine?
[Modified by KC GSR, 4:54 PM 9/6/2002]
New User
pray that two of the bolts are under the oil in/outlets and then just back the bolt off using them to pry the bearing housing off.. you need to take it off uniformly because you could damage the housing or the blades themselves if it comes off suddenly at an angle
Re: I can't get my turbine housing to budge for the life of me... (brian b)
Ok, I went so far as to put a 10 foot steel pipe down my compressor housing, and a 10 foot steel pipe down my turbine housing and my friend and I slowly pulled them apart trying to get that turbine housing to twist. All that happened is we ended up rotating the compressor housing even though it was fully bolted down and tightened, which i know wasn't good for it but i dont give a ****.
Basically it comes down to this: i am so ******* PISSED OFF that i am this close [ ] from just saying **** it and post all of my **** for sale right now. DAMNIT
PM-Performance
12-09-2002 08:43 AM
DigitalFusion
06-19-2002 06:06 PM
