Preparing for more boost, criticize pls?
Old May 29, 2012 | 05:07 PM
TravisBiggie's Avatar
Default Preparing for more boost, criticize pls?
Current mods in sig.
I have a 10lb spring, and I'm going to be buying a manual boost controller. Shooting for 12-16lbs on a stock motor.
Things I'm changing/adding
1000cc injectors
ARP head studs
New clutch soon
Boost controller
And obviously a dyno tune.
Should I worry about my fuel rail or just keep it stock?
ALSO! I have a rebuilt gsr head, should I just slap that bad boy on instead of reusing my stock head? My block is stock, and I am worried about throwing a rod, melting a piston and damaging my head. I bought a lsvtec motor a few days ago and I am in the process of buying rods and pistons, but I am no hurry to do so, and if I use the gsr head, I won't be running as much boost, probably 12-14lbs which is 300-330whp. I want to keep it as safe as possible with the stock block.
Opinions, knowledge, criticism welcome, Thanks.
Old May 29, 2012 | 05:10 PM
Dc4LsTeG's Avatar
EK9
Default Re: Preparing for more boost, criticize pls?
Keep stock fuel rail
Old May 29, 2012 | 06:20 PM
civickiller's Avatar
what im do you have for that gsr head?
Old May 29, 2012 | 06:27 PM
It came with the stock one and I don't have any interest in dropping a couple hundred for a ported one
I do see a 68mm blackworks TB on craigslist, would I benefit from that? **** just remembered I need a MAP Sensor too -_-
Old May 29, 2012 | 09:02 PM
if youre reluctant to buy a skunk2 im, would u buy a vtec conversion kit?
if not stay ls. on average a ls hits 300whp at 14psi. u can save money for your lsvtec build by staying ls for now.
a 10psi ls is pretty quick
Old May 29, 2012 | 09:12 PM
A conversion kit consists of a head gasket, sandwich plate, a plug and the oil line? I planned on buying the plate and hg separately, and I have the line already, unless i'm missing something?
Old May 29, 2012 | 09:14 PM
Dc4LsTeG's Avatar
EK9
Yea that's what they come with. Some will also come with headstuds
Old May 29, 2012 | 09:21 PM
cool. I wish I had my motor here with me so I can understand the gsr head better.
So there is only one oil line feeding into the block, and is that it for oil lines? The guy I bought the motor from said I have to buy an oil pressure switch, will oil be routed to this?
Last but not least, my ecu is currently chipped. Will I need to buy a vtec ecu kit or anything of that nature before I bring it to be dyno tuned?
Old May 29, 2012 | 09:25 PM
Dc4LsTeG's Avatar
EK9
Its an oil line from the block to head, to supply oil to the head. You you need a basemap for your exact setup to at least get you to the dyno.
Old May 29, 2012 | 09:31 PM
alright so will I have to wire anything for vtec? I was under the assumption I have to wire the vtec to the ecu, plus do something with the knock sensor. know I have more research to do, I think I only have to solder a couple plugs from the gsr harness I got, not too sure yet, my motor is ob1 and the harness i got with the motor is obd2
Old May 29, 2012 | 09:37 PM
Dc4LsTeG's Avatar
EK9
Yes vtec needs to be wired if you dont have a vtec harness
Old May 29, 2012 | 10:00 PM
so i've read concluded this kit needs to be installed into my p75 in order to run vtec.
http://www.xenocron.com/vtec-convers...b2871d9fc398cc
Also i'm guessing I have to wire it like so? but this image doesnt go into detail.
Old May 30, 2012 | 07:40 AM
kyden's Avatar
that kit is for your ecu. you have to solder it into the board.
Old May 30, 2012 | 12:18 PM
boosted_D's Avatar
correct, you need to send the ecu to xenocron and have it vtec converted, then wire everything up........
Old May 30, 2012 | 11:54 PM
randy26's Avatar
It'll b better if u just sell ur p75 and buy a p72 or p28 less headache with the fact u might not do it right and damage ur ecu
Old May 31, 2012 | 01:15 AM
Schister66's Avatar
Man U FTW
Which turbo are you running? That makes a big difference in your plans.
-keep the stock fuel rail
-get a 3bar MAP
-convert to LS/VTEC and port the stock GSR IM...take the butterflies out and clean it up with a dremel (the cheap way to make something similar to the Skunk2)
-reliable boost controller
-retune ... if you have access to E85, that adds a bit more safety into the equation (since its ~106oct)
ekhondahudson
Mar 17, 2014 03:46 PM
DutchEG6
Aug 20, 2005 06:29 AM
Mase
Feb 1, 2005 05:01 PM
tonesdef
Jun 11, 2003 05:47 PM
Blown90hatcH
Jul 30, 2001 04:54 PM
