ARP Head Studs
Old Feb 13, 2012 | 02:07 PM
phelpsj2's Avatar
Default ARP Head Studs
Im using ARP headstuds when i put my b16 head back on, is it needed to but the arp moly lube on the threads that go into the block or only the threads that the nuts go on? also should i torque to 80 like the paper says?
Old Feb 13, 2012 | 02:11 PM
Cap'N Chronic's Avatar
Default Re: ARP Head Studs
Might as well do it, I did. It wouldn't hurt to put the lube on both. And yes, torque the nuts to exactly what the instructions say.
Old Feb 13, 2012 | 03:09 PM
civicjunkie17's Avatar
Make sure you clean the threads out before you put the studs in. Any debris in the way will give you inaccurate torque readings. I've always put the moly lube on where the nuts/washers go on the studs.
Old Feb 13, 2012 | 03:26 PM
MRGRIM's Avatar
R.I.P. Mark
no lube on the block threads at all
they go in dry ..hand tight
make sure your block holes are clean
jaron_cc
Apr 3, 2009 07:33 PM
95_red_dc
Aug 31, 2008 06:17 PM
kuja396
28
Aug 1, 2008 10:25 AM
flip1199
Aug 2, 2005 12:28 PM
kabaroo
10
May 21, 2005 10:41 AM
