ARP Head Studs
Im using ARP headstuds when i put my b16 head back on, is it needed to but the arp moly lube on the threads that go into the block or only the threads that the nuts go on? also should i torque to 80 like the paper says?
Re: ARP Head Studs
Might as well do it, I did. It wouldn't hurt to put the lube on both. And yes, torque the nuts to exactly what the instructions say.
Re: ARP Head Studs
Make sure you clean the threads out before you put the studs in. Any debris in the way will give you inaccurate torque readings. I've always put the moly lube on where the nuts/washers go on the studs.
Re: ARP Head Studs
no lube on the block threads at all
they go in dry ..hand tight make sure your block holes are clean |
