Precision turbo help.
I have a JB 6162 going on my built b16. I'm running a -3 feed line. I need to know what size fitting/resistor I need for the top of the turbo.
Totally depends on your oil pressure. If it exceeds the recommended maximum pressure, then step up to a .065 That said, you could likely just install a .65 restrictor from the get go, and it would not hurt anything at all. That is the path I took.
