D15 Home Made Turbo questions
Has anyone actually done this i already know where to tap for oilfeed line and oil return but need to know wat size fittings to use for the oil pan and oil pressure switch.
Also im running a 14b of a 1st gen dsm and will be using -4an stainless steel hose for feed line. Also wat hose size should i use for the return line i hear it has to be very large so oil wont build up in turbo i will be also running the stock pressure switch so what kind of tee will i need And wat fitting size do i need for the turbo feed port
Man U FTW
http://www.stealthmodeperformance.com
they have all of the parts you need, and while you're there, check out my car in the Customer Spotlight
JDMCRX
08-22-2003 08:14 AM
