2000 honda civic si shift problems?????
Old Dec 18, 2011 | 12:17 PM
just_hatched's Avatar
Default 2000 honda civic si shift problems?????
Just swaped a new motor in mad replaced the clutch flywheel. Pressure. Plate and throw out bearing. After. A short test drive pulling in to my driveway the car popped out of first now i cannot get the car to move.
Old Dec 18, 2011 | 12:23 PM
ssmtyper's Avatar
Default Re: 2000 honda civic si shift problems?????
check to make sure your "bitch pin" didnt fall out or mostly out... Had a buddy that this happed to in his GSR
Old Dec 18, 2011 | 12:32 PM
I kept the shift linkage on the trans to avoid the bitch pin
Old Dec 18, 2011 | 12:42 PM
ssmtyper's Avatar
try running it thru the gears with the car off... does it feel/sound like its going in? then have a buddy watch the slave to see if its moving the fork
Old Dec 18, 2011 | 12:50 PM
With the clutch pedal depressed
Old Dec 18, 2011 | 12:54 PM
allmotaR's Avatar
If it goes into gear with the car off, I'm willing to bet the the springs came out of the clutch.
Old Dec 18, 2011 | 12:58 PM
What would cause it to do that
Old Dec 18, 2011 | 01:09 PM
ssmtyper's Avatar
i am thinking it is related to disengagement problem, as while the motor is running it would be next to impossible to put in gear with out disengaging clutch.... but off you can or should be able to run thru gears with little effort clutch engaged or not... so this is why i am saying to have a friend watch the slave while u depress the clutch pedal to be sure the slave is moveing the fork like it should... should move it prolly around and inch or 2, if not then you need to bleed better and if so then the problem could be with the fork... if the fork was reinstalled wrong after having the new throw out put on it could mean you are dropping the trans again to correct
Old Dec 18, 2011 | 01:11 PM
ssmtyper's Avatar
also the fork should return the slave back to original position when clutch pedal is released
Old Dec 18, 2011 | 01:33 PM
I'm thinking now there maybe air in the clutch line
Old Dec 18, 2011 | 01:51 PM
ssmtyper's Avatar
see.... lol
Old Dec 18, 2011 | 02:35 PM
owneyboy's Avatar
what a bout your axles, besides bleeding clutch
Edwaad Truon
Jan 15, 2013 10:24 AM
TmantonyDC2
Jan 21, 2012 09:18 AM
truxvi3tz
Jan 26, 2010 05:00 AM
Condor018
Oct 19, 2006 10:07 PM
Suave99
Apr 25, 2003 08:13 PM
