2000 honda civic si shift problems?????
Just swaped a new motor in mad replaced the clutch flywheel. Pressure. Plate and throw out bearing. After. A short test drive pulling in to my driveway the car popped out of first now i cannot get the car to move.
Re: 2000 honda civic si shift problems?????
try running it thru the gears with the car off... does it feel/sound like its going in? then have a buddy watch the slave to see if its moving the fork
i am thinking it is related to disengagement problem, as while the motor is running it would be next to impossible to put in gear with out disengaging clutch.... but off you can or should be able to run thru gears with little effort clutch engaged or not... so this is why i am saying to have a friend watch the slave while u depress the clutch pedal to be sure the slave is moveing the fork like it should... should move it prolly around and inch or 2, if not then you need to bleed better and if so then the problem could be with the fork... if the fork was reinstalled wrong after having the new throw out put on it could mean you are dropping the trans again to correct
Edwaad Truon
01-15-2013 10:24 AM
