Help with clutch/transmission problem !
Hey guys, my car is a 2000 Honda Civic EX. When I clutch in to shift from 1st to 2nd gear I feel something shake and also hear a spinning sound. 1st to 2nd gets notchy and sometimes my gear grinds. Finally, when I am in first gear cruising in for example, a parking lot every time I gas a little bit the car jerks foward. Any ideas on what these problem this might be? Any help would be appreciated.
Re: Help with clutch/transmission problem !
It happens right when I clutch in to shift to 2nd gear. So right when I press on the clutch pedal to shift to second I feel a sudden jerk and hear a spinning noise. The shifter moves violently.
You probably have several different issues:
-The rear engine mount may be loose or bad, but check all the mounts.
-The clutch throw out bearing may be bad and causing the noise.
-You may reduce the shifting problem by replacing the transmission fluid with fresh Honda MTF.
ThaEfSwap
11-29-2011 06:37 PM
taimysho0
09-24-2007 05:15 PM
