View Poll Results: 160whp goal .. which route would you take to reach it ? (budget build)
boost the stock d15b2 .. (FI)
14.29%
swap to b18c1 GSR .. (NA)
17
80.95%
another route (please describe)
4.76%
Voters: 21. You may not vote on this poll
> if you have a 160whp goal .. would you Boost, or swap to b18c1 GSR ?
Old Sep 25, 2011 | 10:14 AM
street_ride14's Avatar
Default > if you have a 160whp goal .. would you Boost, or swap to b18c1 GSR ?
building on a budget with a conservative goal of 160-170whp. Not looking for anything special, just want a fun daily driver.
my current motor is the d15b2 in my CRX, this is the motor that will be either boosted or swapped out for the b18c1 GSR.
which way would you go to reach a 160whp goal on a budget ?
Old Sep 25, 2011 | 10:56 AM
KINGVEM^^ED6's Avatar
Default Re: > if you have a 160whp goal .. would you Boost, or swap to b18c1 GSR ?
gsr all day with bolt ons
if you boost the b2 id reccomend a rebuild or its not going to last
Old Sep 25, 2011 | 12:56 PM
SpeedwayCoating's Avatar
gsr swap is the simplest solution. but I am a sucker for boost.
Old Sep 25, 2011 | 01:18 PM
racebum's Avatar
with prices these days get the ITR swap. it's only a couple hundred more and you get a LOT more motor {na speaking} and an LSD
Old Sep 25, 2011 | 08:59 PM
dantamparacer's Avatar
b18c in my opinion, then when and if you want more power the motor will handle over 300 on stock internals
Old Sep 26, 2011 | 09:18 AM
406EVO's Avatar
U MIRIN?
b18c son.
Old Sep 26, 2011 | 02:44 PM
TunerN00b's Avatar
For a fun daily with no track desires, boost the D.
I love my B18C1, but the torque of a boosted D would make a more fun daily (that low of a hp goal means a small turbo capable of low RPM boost can be used), and should have no issues getting better mileage with a good tune...
I got spoiled by a 1.8 turbo that only made 170hp, but the 180 lbs-ft at 1,850 it made was awesome around town.
The usability of the powerband is much more important than the peak numbers for a street car.
Old Sep 27, 2011 | 01:46 PM
DeeC2's Avatar
10 Year Member
Icon3 Re: > if you have a 160whp goal .. would you Boost, or swap to b18c1 GSR ?
on a budget i would do a d16z6 turbo swap, Cheaper than a gsr and way faster!!
Old Sep 27, 2011 | 03:36 PM
xile6's Avatar
TO me boost is better plus you can build the motor and turn up the boost later on. A little hard to just up the na power of a gsr
Old Sep 27, 2011 | 05:23 PM
joe b's Avatar
Drop in a b18c1 and youre all set . Remember its going to be EXTREMELY reliable . Boosted sohc will be quicker at first though .
epedomic
Aug 25, 2011 07:28 PM
2fastss
16
Nov 3, 2009 12:23 PM
Carlo
11
Aug 13, 2003 04:53 PM
94hatchback
Mar 3, 2003 01:55 PM
