95 civic electrical problem
Old Mar 28, 2011 | 03:51 PM
jdm ej2 boosted's Avatar
Icon2 95 civic electrical problem
had this car for a month now, and it runs like a champ, but my horn dsnt work, and my srs light is on, any ideas on wat could be wrong? thanks
Old Mar 28, 2011 | 03:52 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 95 civic electrical problem
Aftermarket steering wheel?
Old Mar 28, 2011 | 03:54 PM
nah its factory
Old Mar 28, 2011 | 03:56 PM
The Grumpiest
Same questions I asked the other guy with horn problems.
Just stopped working? Never worked?
Old Mar 28, 2011 | 04:00 PM
i bought it like that
Old Mar 28, 2011 | 04:08 PM
The Grumpiest
Already running horn thread.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/horn-doesnt-work-my-97-civic-2916122/
Did you ask the previous owner about the SRS light?
Old Mar 28, 2011 | 04:12 PM
not really, i though it was jus a blown fuse, but the fuse frm the front under the hood looks fine
Old Mar 28, 2011 | 04:17 PM
Former User's Avatar
Sounds like a bad clock spring (cable reel) in the steering wheel.
Old Mar 28, 2011 | 04:21 PM
where can i buy one?
Old Mar 28, 2011 | 04:24 PM
At a junk yard...but use a multimeter to test the SRS and horn wires for lack of continuity first.
Old Mar 28, 2011 | 04:28 PM
can i buy one , at a honda dealership?
Old Mar 28, 2011 | 04:35 PM
Yes, but it will cost you about $250.
Old Mar 28, 2011 | 04:45 PM
well, theres no junkyard where i live at so i guess thats my only option
Old Mar 28, 2011 | 04:47 PM
The Grumpiest
Ebay.
Old Mar 28, 2011 | 04:48 PM
so i type in 95 civic cable reel?
Old Mar 28, 2011 | 05:09 PM
The Grumpiest
Try it. Tell me what happens.
Old Mar 28, 2011 | 05:32 PM
chaztuna's Avatar
Ron is correct that the clock spring is the most common fault in the SRS system. However, I would not go with a used clock spring. This is a part that wears out from the constant turning of the steering wheel. Any part in the junk yard will be dead or almost dead. That said, scan the SRS [airbag and seat belt system] for fault codes. If you don't scan for fault codes you are just guessing what is wrong. Check the fuses for the SRS system. They are fuses 24 & 25 in the "in car" fuse box.
Another possible problem could be the switch in the inertial reel [retraction reel] for your seat belts. There is also a pressure switch in each seat bottom [so the system knows if someone is sitting in a given seat] This is not a common problem, but does happen from time to time.
Regarding your horn, do the following. Check fuse #42 in the under hood fuse box. If it's OK, remove the power wire from one [if you have more than one it does not matter which one] of your horns. Install the probe end of a 22 volt test light into the connector on the horn wire. Ground the alligator clip to a KNOWN good ground. Turn on the ignition switch and depress the horn button. If the test light comes on, the horn is bad. If it does not come on, the most likely problem is with the horn button. There is a relay for the horn, but this almost never goes bad.
Chaz
Old Mar 28, 2011 | 05:34 PM
chaztuna's Avatar
I'd also check with a quality aftermarket parts store. Dorman Products now carries Airbag clock springs for a lot of popular cars. The Dorman stuff is very good and cheaper than the dealer.
Chaz
Old Mar 29, 2011 | 06:15 AM
Chaz
thanks bro this really helps alot, ill check those fuses today
Old Mar 30, 2011 | 04:17 PM
chaztuna's Avatar
Glad to help.
Chaz
fryguy190
10
Oct 1, 2008 07:14 AM
ge_ej1
10
Nov 8, 2007 07:25 AM
RED_90TEG
16
Apr 19, 2007 07:33 AM
Econo'Box
Mar 17, 2005 12:25 PM
dpine
14
Feb 13, 2005 05:22 PM
